Lagom的单步骤下单插件破解版,官网卖得挺贵的。对用户比较友好,不需要一直下一步下单了。
Download Lagom WHMCS One Step Order Form v1.2.4 Nulled Free v1.2.4 - Released: Dec 18th, 2023
NEW FEATURE
WHMCS V8.9 support
Please note that the new “PayPal Payments” and “PayPal Card Payments” gateways are not currently supported until one of the upcoming major updates
Choose domain configuration elements and impose a custom order in which they will be displayed
IMPROVEMENT
- Added option to ensure that products and product groups marked as ‘Hidden’ in WHMCS are not visible in the browser’s developer tools
BUG FIX
Resolved issue with payment details display on mobile view in the Firefox browser
Fixed problem that could cause the “Order Summary” box to overlap with “Payment Details”, and the icons for payment methods to spread to the side -
Solved case where applying a promotion code could for a brief moment reset the total price in the order summary -
Adjusted the display of starting prices that could be wrongly shown for specific billing cycles and configurable options when the monthly pricing breakdown is enabled -
Fixed problem where paying with the credit balance was impossible if the “Bank Transfer” gateway was unavailable -
Corrected configurable option icons loading from the media library on macOS systems
Adjusted font size used in product tiles on macOS systems
Resolved specific problems with adding to a cart a domain to register or transfer
The cart will now properly reset after switching to another product from the domain renewal view
Other minor corrections related to the display of setup fees and product prices
Solved specific validation problem where adding new domain registrant information could prevent the order completion -
Fixed case where the “Subtotal” amount was not displayed in the order summary
Corrected issue with the hCaptcha solving window
The hCaptcha script will no longer be loaded if that is not enabled in the configuration -
Blocking existing domains will now work properly when providing an owned domain -
Added missing validation for the maximum amount that can be provided into the slider configurable option type
Many other code corrections and UI adjustments
VPC https://vvpp.cc/s/WDlIj 提取码 4dyuga
