Free verification codes available, can be used for GPT
:warning::warning::warning:It seems this one is different from the one the other expert posted before. You all can give this a try.
You can get between a dozen and more than twenty points for free by checking in. 700 points equals $1, so you can quickly earn points. The cheapest GPT is $0.03, which costs 21 points, but it’s out of stock right now. I chose Netherlands :netherlands: 31, which is valid for 15 minutes, and you can receive a code.
AFF Telegram: Launch @llIlIlIllbot
Proof below
Receive code
Available services
Seems to be the same one.
TG simply doesn’t work at all. Posting about it without even testing first—isn’t that just misleading people?
Okay, thanks a lot! I only tried GPT and didn’t try TG, that’s my mistake.
I’m not sure either. I saw that another expert posted a longer name—it seems to be the same type.
My main Vercel account was suspended, so I want to create a small alt account to play around with, but it seems like this one doesn’t work.
Thanks a lot for sharing!
You can register with just a GPT email address—there’s no need for SMS verification. The point is that you simply can’t register for the ones that require it.
For this, it’s still more convenient and less hassle to just get a card yourself.
Logging into Codex through GPT requires receiving a verification code, as do some other services. I haven’t tested the other services either :xhj007:
Google can also be reached.
Not bad.
This is useful—saving it for later.
It so complicated
Thanks, boss! A daily check-in lets me use GPT once.
Thanks for sharing
Thanks, bro.
Are SMS verification platforms still able to reliably receive GPT verification codes? I tried three last month and none of them worked.
Very good project, thank you for sharing.
Can I use points alone to redeem an SMS verification number?
