I’m looking to buy a server with better quality. My current server is severely oversold—so much so that the CPU is completely unusable.
Budget: 40 per year
Specifications: 1 GB RAM, 1 core, 5 GB disk space
Preferably located in China
Network-optimized servers are also acceptable, as long as they aren’t too heavily oversold
I plan to use it to set up a personal AI gateway. Any recommendations?
Detailed requirements
Other than the CPU core count, the remaining specifications should be at least as good as the current setup.
I’m using 澪雨’s Octopus, and it’s running pretty well so far. It currently has 1 core, 1 GB of RAM, and a 2 GB disk, but the overselling is way too severe—I can’t stand it.
Like this? I still prioritize stability and cost-effectiveness. Performance can be a bit worse—as long as it can at least produce an initial result for domestic token plans (such as SenseTime) within 30 seconds.
