n/suggestion · 4 个月前 · 已编辑 · 1285 次浏览
u/520bingge黄金
n/suggestionu/520bingge · 4 个月前
免费的ClaudeproX20
焚绝教了,剩下就靠动手了
使用以下油猴脚本
打开claude网页版,支付资料选择德国,支付方式选择sepa,使用http://randomiban.com/随机生成德国卡号填入直接支付就行了,max20到手
// ==UserScript==
// @name         TestExample Cassia Response Mock
// @namespace    local.testexample.checkout
// @version      1.1.0
// @description  将 checkout_capabilities 响应改写为 cassia
// @match        *://claude.ai/*
// @match        *://*.claude.ai/*
// @run-at       document-start
// @grant        none
// @sandbox      raw
// ==/UserScript==
(function () {
  "use strict";
  const TARGET_HOST = "claude.ai";
  const TARGET_PATH =
    /^\/api\/organizations\/[^/]+\/subscription\/checkout_capabilities\/?$/;
  const MOCK_DATA = {
    checkout_flow: "cassia"
  const MOCK_BODY = JSON.stringify(MOCK_DATA);
  const MOCK_LENGTH =
    new TextEncoder().encode(MOCK_BODY).byteLength;
  function getTargetUrl(input, method = "GET") {
    try {
      let rawUrl;
      if (typeof input === "string" || input instanceof URL) {
        rawUrl = String(input);
      } else if (input && typeof input.url === "string") {
        rawUrl = input.url;
      } else {
        return null;
      const url = new URL(rawUrl, location.href);
      if (String(method).toUpperCase() !== "GET") {
        return null;
      // 允许主域名以及其子域名
      const hostMatched =
        url.hostname === TARGET_HOST ||
        url.hostname.endsWith("." + TARGET_HOST);
      if (!hostMatched) {
        return null;
      if (!TARGET_PATH.test(url.pathname)) {
        return null;
      return url;
    } catch (error) {
      console.error("[Cassia Mock] URL 解析失败:", error);
      return null;
  function createMockResponse(originalResponse) {
    const headers = new Headers(originalResponse.headers);
    headers.delete("content-length");
    headers.delete("content-encoding");
    headers.delete("etag");
    headers.delete("content-md5");
    headers.set(
      "content-type",
      "application/json; charset=utf-8"
    headers.set("content-length", String(MOCK_LENGTH));
    headers.set("cache-control", "no-store");
    const response = new Response(MOCK_BODY, {
      status: 200,
      statusText: "OK",
      headers
    // 尽量保留原始响应信息
    try {
      Object.defineProperties(response, {
        url: {
          value: originalResponse.url,
          configurable: true
        redirected: {
          value: originalResponse.redirected,
          configurable: true
        type: {
          value: originalResponse.type,
          configurable: true
    } catch (_) {
      // 不影响主体改写
    return response;
   * 拦截 Fetch
  const nativeFetch = window.fetch;
  window.fetch = async function (input, init) {
    const method =
      init?.method ||
      (input instanceof Request ? input.method : "GET");
    const targetUrl = getTargetUrl(input, method);
    const originalResponse =
      await nativeFetch.apply(this, arguments);
    if (!targetUrl) {
      return originalResponse;
    console.warn(
      "[Cassia Mock] Fetch 响应已改写:",
      targetUrl.href,
      MOCK_DATA
    return createMockResponse(originalResponse);
   * 拦截 XMLHttpRequest
  const XhrPrototype = XMLHttpRequest.prototype;
  const xhrInfo = new WeakMap();
  const loggedXhrs = new WeakSet();
  const nativeOpen = XhrPrototype.open;
  const nativeSend = XhrPrototype.send;
  const nativeGetResponseHeader =
    XhrPrototype.getResponseHeader;
  const nativeGetAllResponseHeaders =
    XhrPrototype.getAllResponseHeaders;
  XhrPrototype.open = function (method, url) {
    let absoluteUrl;
    try {
      absoluteUrl = new URL(
        String(url),
        location.href
      ).href;
    } catch (_) {
      absoluteUrl = String(url);
    xhrInfo.set(this, {
      method: String(method || "GET").toUpperCase(),
      url: absoluteUrl
    return nativeOpen.apply(this, arguments);
  function getMatchedXhr(xhr) {
    const info = xhrInfo.get(xhr);
    if (
      !info ||
      xhr.readyState !== XMLHttpRequest.DONE
      return null;
    return getTargetUrl(info.url, info.method);
  function replaceXhrGetter(propertyName, replacement) {
    const descriptor =
      Object.getOwnPropertyDescriptor(
        XhrPrototype,
        propertyName
    if (
      !descriptor ||
      typeof descriptor.get !== "function" ||
      descriptor.configurable === false
      console.warn(
        `[Cassia Mock] 无法接管 XHR.${propertyName}`
      return;
    const nativeGetter = descriptor.get;
    Object.defineProperty(XhrPrototype, propertyName, {
      ...descriptor,
      get: function () {
        if (!getMatchedXhr(this)) {
          return nativeGetter.call(this);
        return replacement.call(this, nativeGetter);
  replaceXhrGetter(
    "responseText",
    function (nativeGetter) {
      if (
        this.responseType !== "" &&
        this.responseType !== "text"
      return MOCK_BODY;
  replaceXhrGetter(
    "response",
      if (this.responseType === "json") {
        return {
      if (
        this.responseType === "" ||
        this.responseType === "text"
        return MOCK_BODY;
  replaceXhrGetter("status", function () {
    return 200;
  replaceXhrGetter("statusText", function () {
    return "OK";
  XhrPrototype.getResponseHeader = function (name) {
      return nativeGetResponseHeader.apply(
        this,
        arguments
    switch (String(name).toLowerCase()) {
      case "content-type":
        return "application/json; charset=utf-8";
      case "content-length":
        return String(MOCK_LENGTH);
      case "cache-control":
        return "no-store";
      case "content-encoding":
      case "etag":
      case "content-md5":
        return null;
      default:
          this,
          arguments
  XhrPrototype.getAllResponseHeaders = function () {
    const originalHeaders =
      nativeGetAllResponseHeaders.apply(this, arguments);
      return originalHeaders;
    const headers = String(originalHeaders || "")
      .split(/\r?\n/)
      .filter(Boolean)
      .filter(function (line) {
        const name = line
          .split(":", 1)[0]
          .trim()
          .toLowerCase();
        return ![
          "content-type",
          "content-length",
          "content-encoding",
          "cache-control",
          "etag",
          "content-md5"
        ].includes(name);
    headers.push(
      "content-type: application/json; charset=utf-8",
      `content-length: ${MOCK_LENGTH}`,
      "cache-control: no-store"
    return headers.join("\r\n") + "\r\n";
  XhrPrototype.send = function () {
    this.addEventListener(
      "readystatechange",
      function () {
        const targetUrl = getMatchedXhr(this);
        if (targetUrl && !loggedXhrs.has(this)) {
          loggedXhrs.add(this);
          console.warn(
            "[Cassia Mock] XHR 响应已改写:",
            targetUrl.href,
            MOCK_DATA
    return nativeSend.apply(this, arguments);
   * 显示运行标记
  function showStatusBadge() {
    if (!document.documentElement) {
      document.addEventListener(
        "DOMContentLoaded",
        showStatusBadge,
        { once: true }
      return;
    if (document.getElementById("cassia-mock-badge")) {
      return;
    const badge = document.createElement("div");
    badge.id = "cassia-mock-badge";
    badge.textContent = "Cassia Mock ON";
    Object.assign(badge.style, {
      position: "fixed",
      right: "12px",
      bottom: "12px",
      zIndex: "2147483647",
      padding: "7px 11px",
      color: "#ffffff",
      background: "#167c3a",
      borderRadius: "6px",
      fontSize: "12px",
      fontFamily: "sans-serif",
      boxShadow: "0 2px 8px rgba(0,0,0,.3)"
    document.documentElement.appendChild(badge);
  window.__cassiaMockInstalled = true;
  console.info(
    "[Cassia Mock] 脚本已加载:",
    location.href
  showStatusBadge();
6
28
海外原生IP VPS,稳定访问全球网络
lisahost.com 了解更多
28 条回复
  1. Serendipity1 钻石 4 个月前
    谢谢小晟大佬
  2. lvwa 黄金 4 个月前
    感谢大佬分享!
  3. xiaoyi669 💬 钻石 钻石会员 4 个月前
    谢谢大佬
  4. 520bingge 黄金 楼主 4 个月前
  5. 520bingge 黄金 楼主 4 个月前
  6. ledigl 白银 4 个月前
    无了
  7. Melody 白银 4 个月前
    支付的卡怎么解决,小白不懂
  8. lingfan 黄金 4 个月前
    1.注册一个claude账号 邮箱需要自己试
    2.选一个日本节点
    3.国家德国 Gemany
    4.用这个随机生成一个 http://randomiban.com/
    5.支付方式选择SEPA
    6.iban 生成用这个 http://randomiban.com/
  9. ramudaderuta 白银 4 个月前
    没用
  10. 520bingge 黄金 楼主 4 个月前
    我都成功2个了
  11. ramudaderuta 白银 4 个月前
    不知道,另外一个也创建不成,群里说多换一个,试了十多个都没用,算了还是用0.01的中转省事就是慢点
  12. 520bingge 黄金 楼主 4 个月前
    用你这个插件还能登。刚创的。7.26号22:25分
  13. 520bingge 黄金 楼主 4 个月前
    因为你一句话我又去创建了一个。 :xhj001:
  14. na_lu 黄金 4 个月前
    出现这个是什么原因
  15. lingfan 黄金 4 个月前
    换日本IP
  16. Sike_Yanyu 白银 4 个月前
    没有 选 iban 呀
  17. 520bingge 黄金 楼主 4 个月前
    先在上面选德国
  18. Sike_Yanyu 白银 4 个月前
    选完 了 上面 没有 了
  19. Muqtada 黄金 4 个月前
    Does it still working ?
  20. 520bingge 黄金 楼主 4 个月前
    我现在也不清楚还能不能用,我已经注册3个了。现在3个号都能正常使用
  21. 继续这个对话 →
  22. 520bingge 黄金 楼主 4 个月前
    如果不行,先选其他国家,在选回德国
  23. Foch0x97 黄金 4 个月前
    Unfortunately, Claude is not available tonew users right now. We're working hard toexpand our availability soon.
  24. omen 白银 4 个月前
    这条回复已被版主删除
