Looking for recommendations on mainland-optimized VPS
Guys, may I ask if you have any recommendations or suggestions for affordable optimized route VPS options so far? I want to set up a few for my own use. Recently, I haven’t had a working proxy :smiling_face_with_tear:
I did some AI searching and came up with a few options. I wanted to try vmiss first but it’s always out of stock.
Also, I have another question: in my Shadowrocket app, why do the nodes test successfully, but I can’t open any websites once I connect? Sometimes it says disconnected, sometimes it says unable to establish a secure connection. Not sure if it’s a protocol issue with the nodes or something else. Would appreciate any advice from the experts.
No doubt, 1DMIT EB.INTRO, but it’s out of stock.
I don’t need it. Do you want me to give it to you?
VMISS is a NodeLoc partner merchant.
@LOsEE
:ac10:
Which country do you mean?
Non-expert hearsay: First test the line quality, then check if the script needs to be updated, and finally consider protocol selection (some protocols can be intermittently blocked by X).
Seriously, bro​:grinning_face:
A bit faster is fine. Singapore?
Aren’t there tons of online container playgrounds? Most of them are free.
Which brand is this from? How much is it?
Hong Kong Zone 10 or US Zone 18 might be suitable for you
https://idc-new.ulzix.com/order
OKOK thanks man, I’ll go check it out.
