[UlziX] Half-Year Anniversary – Review ()
Some generous soul gifted me a small VPS. To avoid daily check-ins, I decided to give it a quick try.
Still, I’m very thankful for the server.
The specs are: 1-core CPU, 128MB RAM, 128MB disk, 50GB monthly bandwidth, running Alpine Linux 3.22.2. At a glance, it’s your typical free NAT mini-container—not suited for big projects, mainly for playing around with lightweight services, probes, scripts, or tiny websites.
The control panel is actually quite complete—power on/off, reboot, VNC console, password reset, system reinstall, DNS settings, and IPv4 port mapping are all available. I also tested SSH: after port mapping, I was able to connect just fine, with the public IP mapped to port 22 of the container.
Once inside, the system is extremely clean, and Alpine’s footprint is indeed minimal. The memory limit is around 128MB: free -m shows about 122MB total, with only a few MB used when idle. Disk space is roughly 136MB in total, with the system taking up about 17MB, leaving about 119MB free. Since space is so limited, don’t expect to install much—be mindful of logs and cache too.
The CPU is an Intel Xeon E5-2696 v4 @ 2.20GHz on the host machine, and the container is limited to one core. A quick test running a 32MB sha256 took about 0.43 seconds, which is sufficient for lightweight scripts and small services.
For disk, a simple 8MB write test with fsync gave about 119MB/s write speed. Read speed (thanks to cache) was 3.5GB/s, but that number isn’t the real disk performance. Given the disk is only 128MB, there’s no point in heavy IO testing—you’d fill it up quickly.
Network-wise, the outgoing IP is in Hong Kong, ASN is AS401696 cognetcloud INC. I pinged some common nodes from within the container:
  • 1.1.1.1: average 3ms
  • 8.8.8.8: average 2ms
  • 223.5.5.5: average 24ms
  • github.com: average 36ms
From the container itself, latency to both local HK and international destinations is fine. My own connection to its public IP averages 300ms+, but that depends on local network routing.
One small issue is that the load average seems high, fluctuating between 3 and 4, even though there are actually very few processes in the container—just init, syslog, crond, sshd, that’s it. Most likely, that reflects load shared on the host, not my container filling up with tasks. With free VPS, this is pretty typical.
SSH is enabled inside, and I checked the assigned IP—the IP purity is nothing special, and apparently there’s some abuse history, plus the bandwidth is really low. There’s not much use for it right now. Still, it’s free, so none of this is a big deal.
Because the specs are too low, YABS can’t run the disk test or Geekbench :xhj17:
