With the rapid evolution of projects related to the M365 Copilot protocol translation (hereinafter referred to as “related projects”) and the vibrant development of the community ecosystem, more and more independent developers and tech enthusiasts are joining the effort to build relevant tools. However, in the past, many discussions about pain points, feature needs, and ideas for secondary development were often scattered across various open-source project issues or isolated threads. This increased the difficulty of retrieving information and made it hard to consolidate frequent and urgent needs.
To better connect real user needs with the developer ecosystem, we’ve established this wish pool.
Purpose of this thread
Aggregate core demands: Centralize the collection of your real pain points in using related projects, API conversion, and secondary development.
Support open-source iteration: Provide a reference for planning and optimizing future versions of related open-source projects within the community.
Promote community collaboration: Offer topic ideas for independent secondary developers and boost technical exchange and collaborative development within the ecosystem.
Guidelines for submitting requests
To ensure clarity and retrievability of information, we suggest structuring your feedback as follows:
[Type of Feedback]: (API reverse extension / content development ideas / usage pain points / other)
[Use Case]: (Briefly describe the business scenario or development environment where you encountered this issue)
[Expected Feature/Outcome]: (Specify the behavior or interface spec you’d like open-source tools or APIs to implement)
Developer collaboration statement
We welcome other secondary development teams and independent developers in the community to pay attention to this thread. If any request here catches your interest and you’d like to follow up on development, feel free to reply and discuss under that comment—let’s enrich the technical ecosystem together.
We look forward to everyone’s ideas and suggestions. Let’s work together to build up this section and its ecosystem!
Content development and extensions: I hope you can add a multi-account switching feature.
Usage issue: AI responses sometimes contain repeated content. For example, it should answer A, but actually answers AAAA (this happened when I asked: Please look up and summarize the 2026 World Cup).
My core pain point is that I deploy on a remote server and can’t read or write local files—the default is always the cloud.
I’ve tried several versions from the community, but they all have this problem. I even had AI try to fix it for ages, but still didn’t get it to work.
The “tool mapping/protocol conversion” design of m365-native.
It doesn’t actually execute local tools like read_file or write_to_file; it just converts tool definitions sent by the client into prompts/plugin definitions, then lets the upstream M365 ChatHub generate “tool call intents,” and finally maps these intents back into OpenAI/Responses/Anthropic format before sending them to the client. Actual disk reading and writing must be performed by client-side callers like Roo/Cline/Hermes/Cherry Studio.
It seems you could try adding a prompt to let the AI know that it will be given custom tools.
Also, based on your description, your Agent Harness may not support reading from and writing to local files. Perhaps switching to Claude Code or OpenCode could work?
I’m a complete beginner and don’t really understand the technical details.
I just noticed that when using Roo Code, Cherry, or Hermes to call the official API, they can read and write local files, but the model in this project can’t. I suspect that M365 is configured by default to store everything in the cloud, making it difficult to read and write local files.
I had the AI modify it more than ten times, but it still couldn’t solve the problem. It was beyond my abilities, so I eventually gave up…
I’m not sure about the other two, but hermes should work in theory, right? After all, it’s an agent. Try updating it, then add the custom command in the official M365 web version and see if that works.
I can totally do it myself. Reading and writing files is basically just letting the AI call a tool, so it doesn’t really have anything to do with whether it’s in the cloud or not.
Also, it’s not the server that’s reading and writing local files—actually, the execution phase of tool calls is always running locally on the client (software like Roo, Cherry Studio, Cline, etc.).
Token input and output are only displayed on the web UI; they are not passed to the response body. The usage field is missing and shows as empty, even though the actual response content is normal and tool calls also function correctly.
Just asking if I don’t understand—right now is there no way to use raw images
By the way, here’s a little flaw I noticed when I used to play: sometimes the model would send garbled text when replying (like some weird content repeatedly popping up in one message, for example, HUXO)
Date/time: 2026-08-07T01:12:16.200Z
Extension version: 3.76.0
Provider: openai (proxy)
Model: gpt-5.5
The model provided text/reasoning, but did not call any required tools. This usually means the model misunderstood the task or had trouble figuring out which tool to use. The system has automatically prompted the model to retry with the correct tool.
More details about the error:
"role": "assistant",
"content": [
"type": "text",
"text": "The tool was rerun and a solution file was generated; please refer to the tool's output for the final result.\n\nGenerated file: \n[calculator_gui_plan.md](https://kr-prod.asyncgw.teams.microsoft.com/v1/objects/0-ea-d2-3c0543d77a3d5e9c2881a0364b7a7047/views/original/calculator_gui_plan.md)\n\nThe tool was rerun and a solution file was generated; please refer to the tool's output for the final result.\n\nGenerated file: \nciteturn1file1\n\nConfirmed items:\n\n- The solution file was successfully created in the current running environment.\n- The file name is `calculator_gui_plan.md`.\n- The content includes a complete development plan for a Windows GUI desktop calculator.\n- The plan covers:\n - Python technology selection\n - Tkinter GUI design\n - History recording function\n - Separate line display for calculations\n - Project structure\n - Module division\n - Data flow Mermaid diagram\n - Test plan\n - PyInstaller packaging solutions\n - Implementation Todo List\n\nUnconfirmed items:\n\n- I can't directly verify whether the file has been written to your local `G:\\jisuanqi` directory.\n- What can be confirmed is that the file has been generated in a downloadable environment, so you can download it and then save it to `G:\\jisuanqi\\calculator_gui_plan.md` or `G:\\jisuanqi\\plans\\calculator_gui_plan.md` on your machine."
"ts": 1785937686220
"role": "user",
"content": [
"type": "text",
"text": "[ERROR] You did not use a tool in your previous response! Please retry with a tool use.\n\n# Reminder: Instructions for Tool Use\n\nTools are invoked using the platform's native tool calling mechanism. Each tool requires specific parameters as defined in the tool descriptions. Refer to the tool definitions provided in your system instructions for the correct parameter structure and usage examples.\n\nAlways ensure you provide all required parameters for the tool you wish to use.\n\n# Next Steps\n\nIf you have completed the user's task, use the attempt_completion tool.\nIf you require additional information from the user, use the ask_followup_question tool.\nOtherwise, if you have not completed the task and do not need additional information, then proceed with the next step of the task.\n(This is an automated message, so do not respond to it conversationally.)"
"type": "text",
"text": "<environment_details>\n# VSCode Visible Files\n\n\n# VSCode Open Tabs\n\n\n# Current Time\nCurrent time in ISO 8601 UTC format: 2026-08-05T13:48:06.412Z\nUser time zone: America/Los_Angeles, UTC-7:00\n\n# Current Cost\n$0.00\n\n# Current Mode\n<slug>architect</slug>\n<name>🏗️ Architect</name>\n<model>gpt-5.5-reasoning</model>\nYou have not created a todo list yet. Create one with `update_todo_list` if your task is complicated or involves multiple steps.\n</environment_details>"
"ts": 1785937686415
I just tried adding a system prompt to my account, but it still can’t write files locally, as shown in the screenshot below. You’ll need to manually download and save the file.
I’m using Windows 10, and when I use the m365 model in zoo code, Cherry, or Hermes, any attempt to read or write local files gets redirected to /mnt/data.
Here’s the analysis the AI gave me at the time:
The remote m365-native.exe acts as a protocol bridge, stably converting Copilot Web model's tool intent into the local tool invocation format already supported by these clients.
If the client still ends up in /mnt/data after receiving a correct tool invocation, then it's an issue with the client workspace/tool execution environment configuration; if the client can't recognize the tool invocation, then the m365-native.exe output protocol still needs further compatibility adjustments.
