A\ inexplicably committed necrophilia against me
This account was already banned for me back on Feb 13, but then it got banned again on Aug 5.
This further proves that A\ bans accounts based on association. The link between these two accounts of mine is probably the IP and machine ID.
So if you’ve ever had an account banned by A, you definitely need to change your IP. If you can’t change your machine ID, you can run things in a virtual machine. I use WSL more often, so just starting up another WSL environment works fine.
It could also be a problem with the card—I just noticed my card was declined by Claude.
I really can’t figure out A's account banning logic, but it seems like they look at email reputation. I noticed my older accounts with higher reputation never got banned, but all the new ones I created were banned.
Indignant with rage! They won’t even leave the corpses alone—this is just too much :enraged_face:
So stay away from A\
Stay away from A​:divide: for your safety.
By the way, will A\’s ban (封号) get a refund, or do I need to dispute it first to get the refund?
The refund was processed quickly and based on the remaining time.
Besides using conventional methods such as IP addresses and card BINs to ban accounts, A-dog also uses the aforementioned Trojan clock to determine whether a user is Chinese. In short, avoid using it if possible.
Stay away… stay safe
glm got banned, and they still won’t give you a refund :xhj34:
