Helpful Tips
Your phone must support eSIM functionality to scan and install the eSIM (mainland China models do not support it; reportedly, the iPhone Air can do so by changing its location through WLOC).
Phones that do not support eSIM can spend an extra 20 on Pinduoduo to buy a Xiaobai card, install the easyEUICC APP on an Android phone or use an eSIM card reader to install it, and then insert it into the phone’s SIM card slot.
Tutorial: https://zhuanlan.zhihu.com/p/1929485386121479322
Order link with discount code:
https://pay.ldxp.cn/item/qxr3m2
Order link for a pre-made number (WiFi Calling enabled):
https://wzyp.cn/item/6lvnuu
Order link for a pre-made number (WiFi Calling not enabled):
https://pay.ldxp.cn/item/vwb4lo
Difference: After topping up a pre-made number with WiFi Calling enabled, you can directly send an SMS to keep the number active
Just purchase through one of the links above.
If you have never registered before, it is recommended that you buy a pre-made number. The discount code can only be used once!!!
It is easy to make a mistake during the first attempt, which may cause activation to fail and the discount code to become invalid at the same time.
For reference: Tutorials on registration, activation, keeping the number active, and porting your number:
How to keep a VOXI number active
While on Paygo, any balance activity (such as topping up, making a call, or sending a text) refreshes the validity period and extends it by another 180 days.
VOXI’s minimum top-up amount is £5 GBP, and you will receive an SMS notification 90 days before your number expires.
Sending an SMS from China costs only 0.08 GBP ≈ 0.8 RMB per message, and under WiFi Calling it costs only 0.01 GBP, approximately 0.1 RMB!
Recommended simplest way to keep your number active:
The best way to keep your number active is to proactively send an SMS once every 180 days.
成品号和优惠码已补货
另外手机不支持eSIM,可以在多多花20块买一个“小白卡”,通过Android手机扫码写入
August 11 Discount Codes and Ready-made Accounts Restocked and Now Available
Order link for discount codes:
Order link for ready-made accounts:
Two Solutions for Voxi eSIM Long-Term No Signal Issue
Here are two solutions:
Go to a place outdoors with good signal reception, wait for about 3–5 minutes, and you should get a signal. This is a simple and quick fix in emergencies, but when you return indoors, you might lose signal again.
Change your APN settings. The steps are a bit different for Android and iOS. This method is a permanent fix and is highly recommended.
For detailed instructions, check out the following video (already set to the precise part):
Extra:
Discount code order link:
Ready-to-use account order link:
PS: If your phone sold abroad doesn’t support eSIM, you can buy a “Xiaobai Card” (Little White Card) on Pinduoduo, then scan and write the eSIM with an Android phone.
📱 Android Manual Settings Checklist
Official APN: VOXI uses the Vodafone network; the standard settings are:
● Name: Talkmobile PAYG
● APN: payg.talkmobile.co.uk
● Username: wap
● Password: wap
● MMSC: http://mms.talkmobile.co.uk/servlets/mms
● MMS Proxy: 212.183.137.12
● MMS Port: 8799
● MCC: 234
● MNC: 15
● APN type: default,supl,mms
📱 iPhone Manual Settings Checklist
1. Cellular Data (top main section)
Username: wap
Password: wap
2. LTE Setup (optional)
Username: wap
Password: wap
3. Visual Voicemail
Leave blank — don’t enter anything.
4. MMS (scroll down)
Username: wap
Password: wap
MMS Proxy: 212.183.137.12:8799 (Note: use a colon :)
Max MMS size: Leave as default (e.g. 307200)
MMS UA Prof URL: Leave blank
5. Personal Hotspot (at the bottom)
Username: wap
Password: wap
August 13: Both Finished Accounts and Promo Codes Restocked
Order link for promo codes:
Order link for finished accounts:
August 14th: Finished accounts and discount codes have been restocked; feel free to place your order if you need them
Link to order with a discount code:
Link to order finished accounts:
August 16th: Stock Replenished for Ready Accounts and Promo Codes
Order link for ready accounts:
All ready-made accounts in the shop were restocked and newly listed on August 18
Ready-made account order link:
August 19th Store Pre-Made Accounts Restocked and Listed
Pre-made account order link:
August 20: Store promo codes and pre-made accounts have been restocked and newly added
Promo code order link:
Is there a tutorial for getting WFC working with root? If so, could you put one together?
See my blog:
There are other tutorials there too.
Does this mean it didn’t use any other devices as transparent proxies? Is VOXI particularly easy to get working? I feel like I’ve never managed to get any other SIM cards working.
I just used the v2rayN app directly.
Isn’t this for computers?
I’m using Android with a Mac right now, and there aren’t any tutorials.
I did the whole thing on my phone. Just follow the steps. If it doesn’t work, then there’s nothing I can do either.
