Why is my MC2A latency so high?
It’s the same whether remote or local.
We’re all the same—if it works, that’s good enough.
(Obviously they’re only saying that because it doesn’t work)
It seems that QwenPaw can’t be called properly—either it times out, or MCP can’t be used.
It’s callable.
I did the Go compilation directly on qwenpaw.
The test script also received responses from the model and returned the number of tokens used.
I’m not sure if it’s an issue on my end, but the speed is really slow.
I compiled it separately and ran it on a server.
I don’t understand, but I’ll bump your thread for you.
Mine is pretty much the same, but it can be a bit faster when making calls.
Getting ready to optimize TLS warm-up—it might save 3–4 seconds.
(Never going back to WS reuse again, it’s too risky, and it only saves 1–2 seconds anyway.)
Remember to optimize memory usage, otherwise my container restarts every two hours or so.
Now I can answer!
Seems I know why Microsoft 365 Copilot is so slow to respond upstream - Technology & Creation / M365 Copilot - NodeLoc
