[UlziX] Final survey on operation models for Hong Kong Free Zone (choose one of three)
Hello everyone,
Regarding how the Hong Kong free zone should operate, there are currently two different opinions. Some feel that the queue-and-rotation system is too cumbersome and want to return to the previous resource-grabbing system; others believe that the queue-and-rotation system at least guarantees availability at some point and support the current model.
Current status:
The simultaneous online container limit has been increased from 100 to 150, easing the pressure on the queue somewhat.
The two options are as follows:
Option 1: Restore the resource-grabbing system (original model)
  • No limit on simultaneous online users; first come, first served, with users competing for resources;
  • Those who manage to claim resources can use them, while those who do not may have to wait and may be unable to use the service;
  • No 7-day release limit and no queue;
  • Some users may occupy resources for a long time, causing later users to experience lag or possibly be unable to connect.
Option 2: Keep the queue-and-rotation system (new model)
  • A limit of 150 simultaneous online containers; those exceeding the limit must wait in the queue (the first 100 are currently being created, and the additional 50 are expected to be fully created before 11:00 on the 16th);
  • Each instance can run for a maximum of 7 days, after which it is released to make room for the next user;
  • Queued users are automatically assigned available slots, ensuring fair rotation;
  • Everyone gets a turn, but must accept the queue and 7-day release rules (or an adjusted duration).
Which option do you support (1 or 2/3)? The final decision will follow the wishes of the majority, with the minority respecting the majority (if the difference is small, we will not switch, as changing it is too much trouble).
This poll is open until August 18. After it closes, we will implement the result and will not make any further adjustments.
Final Survey on the Operating Model for the Hong Kong Free Zone (Choose One of Three)
  • Restore the resource-grabbing system (original model)
  • Keep the queue-and-rotation system, rotating every 7 days (new model)
  • Keep the queue-and-rotation system, but change the rotation period to 1 day, 14 days, or another duration; you may reply to the post to discuss it (expanded option for the new model)
0 投票人
原模式就挺好
好像也可以临时用其他地方的机器临时代用,原11区啥时候恢复,啥时候停,用的好付费相信也会更放心
保证基础公平,再加入资源竞争。不过就怕有人拿去整天跑流量,占用带宽
免费机器肯定不能换到其他区影响付费用户的
This kind of monitoring is too much trouble; it’s impossible to keep checking all the time. If just one of many machines is busy, the whole system is marked as highly occupied, and you can’t pinpoint which one is the problem.
嗯,忘记了目前就香港有免费机
So it turns out that HK11 is now automatically migrated to Zone 14! Will it be possible to revert this in the future?
看原机房如果处理就能,不能就新区
抢资源有人会挂机器人
Is the vanilla version even usable? I can’t even manage it—it’s so laggy I can’t open anything, and none of my commands go through :ac01:
Cancel, delete everything, repurchase, limit the quantity per person.
可以加个选项四
选项四:长期稳定租约模式
香港免费区划分为长期池和轮换池。长期实例最低保障使用 180 天,满足活跃、续期和合规条件的用户可以无限续期,不因单纯使用时间较长而回收。
当资源满载时,平台首先回收违规、多账号、主动释放及长期闲置的实例。如果长期池持续满员并存在排队,只对连续使用超过 12 个月的实例进行少量公开随机轮换,每月轮换比例不超过长期池的 5%,并提前通知及保留数据快照。
长期实例优先提供给从未获得过长期资格及历史免费资源使用较少的用户,同一优先级通过公开抽签决定。平台同时保留部分轮换实例,供正在等待长期资格的用户临时使用。
这太复杂了吧,我现在这个轮换逻辑都没做完 :ac10:
Has anyone actually shared whether the old resource competition method is still useful…? Even the container panel itself can’t stay up — what are the machines that manage to grab resources actually running…?
To take it to the extreme: with the competition method, one of the few things these small machines are actually good for is running scripts to scan other machines. They don’t even need to be continuously available; as long as a process stays alive and scans intermittently, that’s fine. If there are such cases, eventually the root node is going to get abused.
Also, since the machines are free, the platform can make its own decisions. Once a decision is made on a certain solution, at least try it for a while to see if it works, unless it really proves unworkable.
Leaving it up to user votes isn’t a long-term solution. If you bring back the competition method, you’ll probably get a flood of feedback in a few days saying it’s unusable, and the objections to the 7-day queue will probably disappear again.
There was no problem when it was created, but I hardly ever connected to it afterwards.
It still works; making this change is similar to how you might not be able to access the panel after your subscription expires, but if you save your SSH info, you can still use it.
I’m considering what this user said, but if I do that, there will be even more opposition.
Objectively speaking, limiting the number of devices is the best solution. Whether you agree or not, this thing is free to begin with…
I’ve honestly never seen a business model where users have to fight each other for computing resources, and the platform can’t even track what exactly a VPS is using. The only way to deal with downtime is to reset the host. Isn’t this basically inviting people to mess things up?
We won’t be handling issues in the free zone anymore. Dealing with some of them still leads to other problems, so we’ll just go with the flow and let things be—this is the new policy. Yeah, we’re not changing it.
免费机器放出来太多了,这个是最大问题,最活动没有计算好母鸡的承受力
