I noticed that all data is stored locally in the browser by default. Could you clarify whether saved data such as email notes will be lost if I switch browsers or clear the cache? Also, it would be more convenient for MJJ users managing multiple accounts used for registrations if a feature were added later to automatically categorize temporary emails.
Yes, but this isn’t a major issue. I’ll add a feature later for exporting and importing notes. As for categorization, I won’t implement that after all. After all, the purpose of this plugin isn’t to become a third-party plugin covering every email function. Its main feature is quickly receiving various verification codes—that’s the core requirement.
Replying to emails and composing messages are only intended for simple replies to ordinary emails. They aren’t core requirements, but rather personal conveniences I wanted.
Every tool should address its core requirements. There’s no need to make something overly broad and all-encompassing; for needs like these, third-party software is more comprehensive anyway.
Is there an app for this?
Probably not… I didn’t see it.
Not bad, not bad.
Welcome! For normal optimization, log in using the backup data and sync the information, haha. You can also wait a little while before using it.
The feature you requested is ready. You can log in directly using the encrypted data from the backup, or import it from the Settings page. This makes syncing data across multiple devices easier.
Okay, thank you.
