Why has the forum been so slow lately? What's causing it?
Why has accessing the site been so slow lately? Is it because there are too many visitors after registration opened?
I can access it without any lag—it runs quite smoothly.
The experience is pretty good overall, though some nodes may be slow. If one is, just switch to another.
Cloudflare issue
@James Has made so much money :dollar_banknote:, yet still won’t buy the commercial version of CF
:xhj30:
It’s the same—the nodes are identical. There are just more rules.
:face_with_crossed_out_eyes:Going back to a self-hosted CDN?
Once the app goes live, it won’t lag anymore.
I didn’t really notice any lag.
It was fine the whole time.
It’s probably a problem with your network, right?
It’s not laggy; it has to do with the local nodes. At the moment, everything loads very quickly with just a quick refresh.
I’m doing okay. I’ve always been pretty process-oriented.
Please use itdog
The Webmaster’s Home section is finished
It lags just as much. I’ve used Bug before, and it turns out it’s not as good as the preferred option.
No problem on my end.
Consider CF optimization.
Or split traffic between EdgeOne and CF.
You there, bro?
@Mike-Leone You there, bro?
Do I need to use a node to access the forum?
Hello
