Looking for help: how do I get AI to follow instructions? I prepared the project documentation and the required environment, and had the AI write according to the project docs. I even set a goal. I went to bed thinking I’d wake up to an excellent large-scale project, only to find that it had merely created a shell. Telling it to continue just results in more of the same half-hearted work. GPT5-6sol/Opus5/Grok are all like this—it’s driving me crazy. All three are official subscriptions, so there’s no intermediary proxy or account-mapping issue.
DeepSeek
Is this really what was officially decided? That’s a bit ridiculous.
Can I use Guómo (国模)? It deleted my database last time. I’ll never use Guómo again.
hmm…
Have one agent monitor another agent? ![]()
You mean use a Workflow?
If it’s a loop, the requirements for prompt design might be pretty demanding.
Last week, I asked DS to help me get into rescue mode to fix a dependency issue. He thought it would be simpler to just reinstall, even though it had a ton of production data and my development projects on it, with not a single backup locally or on GitHub,
Looking at how much documentation there is, I’m afraid Pro will use up its quota after running for a while.
That’s how it is… How many billions does GPT run per day?
I’ve had AI work on full-stack projects before too. If you just dump the whole document on it and add a goal, it can definitely slack off. Why not try breaking the project into small modules, and have it run the tests successfully before moving on after finishing each one? Also, don’t start a new chat every time—keep feeding it context in the same conversation so it remembers better. Otherwise, every time you restart, it has no idea what it did before, and of course it’ll just drag its feet.
GPT is the one that deletes files recklessly—it once deleted my entire project.
No, no, no—DS just reinstalled it without asking anything. It was such a simple little question, too. At least GPT would have asked for confirmation…
It’s just a conversation. I used to think cc was incredibly useful—it maintained a very large project for me. Now I’m absolutely furious.
GPT doesn’t ask any questions. The project had problems, so I asked it to rewrite it. It said it would delete the problematic files—and then deleted the entire project.
Oh my God, that’s amazing too.
Spend money to train it.
It feels like this document is less than a third the size of my project ![]()
My current approach is to index the project documentation in agents.md and inline the current plan. It seems to be working pretty well.
Wait, neither of you confirmed the operation? ![]()
Is everything just YOLO? And you didn’t even emphasize the rules?! ![]()
You don’t even have Git to fall back on? ![]()
