yooxi
August 25, 2026, 4:01am
If you like MiniMax-M3, check this out.
GMI Cloud has now opened access to MiniMax-M3 — you can try it for free.
Steps
Register and create a key AFF https://console.gmicloud.ai/
api: AFF https://api.gmi-serving.com/v1/
Model: MiniMaxAI/MiniMax-M3
I got it working, here are some pitfalls I encountered:
I couldn’t get the verification email when registering with QQ mail, not sure if that’s just me. In the end, I verified with 163 mail by clicking the link.
The key is super long…
I’m using Zcode, after configuring it and clicking test, it showed failure, but using it directly worked just fine. Not sure about codex, hermes, or DSH yet.
Successful call screenshot
In the end, Niulai is still unbeatable. I just prefer the Niulai model. Rumor has it it’s from Zhipu (not spreading rumors, not believing rumors, not passing rumors), but it’s really good!!
20260826 22:00:00
Niulai model removed from all channels.
Niulai model claimed by Zhipu.
Zhipu released GLM-5.3-Flash.
LOsEE
August 25, 2026, 4:05am
Thanks for sharing, bro (it doesn’t look like an affiliate link, so why is it marked as aff?
lizi
(Lizi)
August 25, 2026, 4:07am
Thanks for sharing, but remember to change the section so you don’t get automatically banned by the AI.
yooxi
August 25, 2026, 4:12am
4
It’s AI-generated—would you believe it?
yooxi
August 25, 2026, 4:13am
5
This is the AI section. What else needs to be changed?
LOsEE
August 25, 2026, 4:18am
6
Okay, but this one is getting 429 errors way too often. I’ll pass.
yooxi
August 25, 2026, 4:19am
7
I’m using it now and it works great—pretty fast, too. It doesn’t even seem to think…
LOsEE
8
Maybe my context is too long, but with Niulai, I basically never get a 429.
yooxi
August 25, 2026, 4:20am
9
I do feel that Niu Lai is slower, though it could be because of the context. I’ll make do with it for now—it’s all free anyway…
LOsEE
August 25, 2026, 4:21am
11
The bull comes really quickly; its speed should only decrease after a certain amount has been used.
yooxi
August 25, 2026, 4:23am
12
It’s also possible that I’m making too many requests and asking for too many changes, which makes things a bit slow—each task takes about 20 minutes.
lizi
(Lizi)
August 25, 2026, 4:28am
13
Since it includes AFF, I guess it should be moved to the deals section, right?
chen_yuan
(我乃半步黄金)
August 25, 2026, 4:32am
14
Thanks, boss. I see there are many models—can the others be used too?
yooxi
August 25, 2026, 4:37am
15
This is a direct link to the official website, with no promotion. The AI tagged it for me…
yooxi
August 25, 2026, 4:38am
16
You have to look at the price. M3 is currently free.
azhaoyihao
(azhaoyihao)
17
Thanks for sharing. I’ll give it a try.
GMI Cloud API Endpoint (confirmed)
yooxi
August 25, 2026, 5:13am
19
Yep. Time to start pedaling.
