I previously submitted a registration request through the invitation bot on Nodeseek and was successfully issued an invitation code, but I noticed that more than 24 hours had passed since the approval message—that is, the code had expired. When I tried applying again, I couldn’t. Is it really impossible to request another invitation code from the bot? (I saw that failed applications can be resubmitted after 24 hours, but if an application is approved and you forget to redeem the code, are you unable to apply again?)
It’s such a shame that I missed the deadline (and I hadn’t seen any notice beforehand that the invitation code had an expiration period…). Now, when I click to apply, it only says, “Each person may apply for only one invitation code.” Could someone knowledgeable explain this? Is there any other way to fix the situation?
That’s right—if you miss it, you miss it. It would only be a problem if one account could apply an unlimited number of times.
Just pay and it’s fine ![]()
But if it doesn’t pass, you can apply again after 24 hours, right?
Sign up now while you still can!
The main issue is that I didn’t notice it would expire in 24 hours when applying
. I really missed my chance, since I can’t keep an eye on Telegram every day. If the notifications were sent directly within the country, I feel like they’d be more timely (please don’t recommend forwarding or anything like that).
Try applying with another Telegram account or buy an invitation code.
Please move NodeSeek-related topics to the dedicated section.
Sorry bro, I only see nodeloc. If I want to switch to nodeseek, which “n/” tag should I switch to?
Due to a [categorization error], the node has been changed from Discussion to NodeSeek Dionysus Precious Moments.
Just type n/nodeseek
Sorry bro, when I tried to pick a category before posting, I couldn’t find anything related to “nodeseek.” Is it because I’d never joined it before? So do I have to search for the keyword first every time before posting? (But I noticed that if I don’t use a regex search like “n/nodeseek”, it doesn’t seem to show any nodeseek-related categories.)
You can search by category directly from the homepage.
Also, you haven’t done anything seriously wrong, so there’s no need to apologize. Please don’t bring the kneeling-forgiveness culture from other forums here.
This kind of goes against the original purpose of registration, right? I’m just asking a simple question
Because it seems like if your application is rejected, you can keep applying as many times as you want.
Okay, thank you. I’m just being a bit careful since it’s my first time asking here (honestly, it’s because other sites can be a bit strict). Also, the reason is that in my very first “newbie” post, a senior member jokingly said they’d “treat” me to a “report,” so I’m just trying to be more careful. ![]()
I want an invitation code.
Does registering still require an invitation code? I remember you could just enter some random nonsense and register successfully.
What’s needed now is that Cao Cong entered the industry relatively early.
Just buy one—it only costs a few bucks.
