That U1S1 platform yesterday was really shady — inflated rates by ×4.67 and overcharged by 367%
rt, didn’t they launch the U1S1 free token package event yesterday?
Someone said this package runs out really fast, so I went ahead and tested it:
Test prompt Expected Difference Status
Round 1 non-streaming · Hi 84 3 +81 :red_circle:
Round 1 streaming · system+user 21 21 0 :white_check_mark:
Round 1 non-streaming · system+user 100 21 +79 :red_circle:
Round 2 non-streaming · same input 21 21 0 :white_check_mark:
Round 2 streaming · system+user 100 21 +79 :red_circle:
Round 2 non-streaming · system-only
This is only what the API returned; checking the backend at this point, it shows: 1,400 tokens
Input: 830
Output: 590
(I specifically waited for the reset to complete before testing)
So, it’s like there are two inflated counts:
Actual consumption (theoretical value) ≈ 300 tokens
API returned = 618 tokens ← First inflation (+106%)
Billing = 1,400 tokens ← Second inflation (+127% more)
Combined, that’s about 4.67x markup—367% extra counted
No wonder it’s not durable (of course, there might be issues with my test scripts, etc.)… :xhj24:
So the so-called free package claims 10 million tokens free per day, but it’s actually about 2 million tokens…
(By the way, this free event got milked hard and is over now)
But if you already got it, you can keep using it for now! :ac01:
But people probably won’t be paying to use it anymore….
Assume the project structure and core code contain 50K tokens (approximately 30,000 Chinese characters).
​Round 1: 50K Input + 1K Output = 51K consumed
​Round 2: 101K Input + 1K Output = 102K consumed
​Round 3: 152K Input + 1K Output = 153K consumed
In other words, after just 10–15 rounds, the cumulative token usage can easily exceed 1–2 million! Burning through the entire quota within half an hour is perfectly normal.
:xhj24:
If it’s free, don’t expect too much.
This is already very good.
Thanks for testing with real data—only with proof like this can some fanatics calm down.
It just stopped working while I was using it. The desktop version won’t reply to any messages, and there are no prompts or notifications at all. I have no idea what the reason is.
Is it absolutely necessary to use the specified tool?
This is already very good! Thanks for sharing.
You can actually write 2API; it’s just authentication. Each time, use an algorithm to generate a User-Agent header :ac01:
You really went to a lot of trouble—I’ve never seen such thorough testing. It leaves no unscrupulous sellers anywhere to hide and exposes all their shady practices to the light of day.
