Sharing a script for automatic 'spark renewal' on Douyin
Lately, while browsing Douyin, I’ve often come across scripts that automatically keep the streak going. I found one on GitHub and decided to try it out—it works pretty well. The documentation says it requires 2c2g, but I think 1c1g would work too; the memory usage is just a bit high. I happened to have a 2c2g machine from CC, so I deployed it there. It’s nothing special, really. Here’s the script:
cd /root
bash install-douyin-sparkflow.sh
Thanks for sharing
You must like it before watching!
What does “续火花” do?
What is a spark?
Thanks for sharing
Where is the shared script?
That’s the string above the image.
Hahaha, everything can be scripted.
So high-end, grand, and classy.
It would be great if it supported integration with the Qinglong panel.
