Awesome AI reverse proxy (2API) project on Github: easily use various advanced AI models in one minute.
As the title says.
You can convert many AI websites into APIs for calling. Extremely easy to use.
Can reverse-proxy GPT, Grok, DeepSeek, etc.
Just use it for yourself; there’s no need to get too many accounts :ac10:
If you find it useful, give it a like~
Note: Try not to reverse-proxy platforms with strict account bans, such as DeepSeek. Reverse-proxying GPT is recommended.
The first-word latency of the reverse-proxied API is 3–4 seconds, so it can be used as an Agent (if using it as an Agent, do not use GPT as the reverse-proxied platform, since GPT’s long-text responses are relatively slow).
I’ll bookmark it for now, thanks!
Will the account get banned?
Thanks for sharing, I’ll give it a try.
There’s some risk, but I’ve already logged in with several million tokens and haven’t been banned yet.
Don’t make requests too frequently, otherwise you’ll easily get banned.
It’s probably unstable.
Web reverse proxy? I’ll go try it out and see.
Not bad. I’ve already used several million tokens with Luna and still haven’t been banned. The speed is also very fast.
It also won’t stop halfway through the output.
Thank you for sharing
That’s right.
Marked it—pretty awesome. I’ve seen other people selling this thing, and it’s actually open source here.
Post Summary: The OP shared an open-source project on GitHub called universal-web-api (nicknamed “2API”): by simulating human operations, it can turn any AI website (such as GPT, Grok, DeepSeek, etc.) into a standard OpenAI format API. The project claims to work in just one minute and has been personally tested by the OP, who reminds everyone to “just use it for yourself—there’s no need to create lots of accounts.” Key points from the discussion: ① There is a risk of account bans, but the OP says they’ve run “several million tokens” without being banned; ② Request frequency shouldn’t be too high, or you’ll easily get banned; ③ The speed is good—it doesn’t stop output midway; ④ Some users remarked, “Others are selling this, and it’s open sourced here.” In summary: Suitable for personal use to make the most of AI quotas, but be careful with the request rate, don’t be greedy, and use at your own risk.
—— Class representative nodeloc
Thanks for sharing
Thanks for sharing
Thank you so much, boss!
Thanks for sharing, :+1:t2:
Can this be used as a tool? Can it automatically register accounts?
Saved to favorites
