The official release v0.6.5 includes the following updates:
Account Scheduling & Failover
- Support for binding an API Key to one or more outbound accounts
- API Key requests will be scheduled only within the specified bound accounts
- If a bound account is rate-limited or fails authentication, failover can occur among other bound accounts
- Fixed an issue where failover might have unauthorized use of unbound accounts
- Explicitly selecting an unbound account returns a clear permission error
- Streaming, non-streaming, and tool invocation paths all now consistently enforce account binding constraints
Rate Limits & Quota Status
- Optimized account rate-limit, cooldown, and recovery detection logic
- Controlled probing is used after cooldown ends to avoid multiple requests hitting upstream at once
- WebUI now clearly labels quota as an “Upstream Quota Snapshot”
- Rate-limit or cooldown states take precedence over historical quota display
- The cooldown notice now says “Recheck in X minutes”, with no guarantee of resumption at that time
Responses & Tool Invocation Compatibility
- Improved parameter handling for Responses requests
- Enhanced call_id, streaming events, and error mapping for tool invocation
- Fixed issues with duplicate tool call IDs and certain tool state correlations
- Improved isolation between different clients, requests, and sessions
- Added /responses as a compatibility entry point for /v1/responses
Network & Stability
- Improved WebSocket connection closure and handling of slow consumers
- Non-idempotent POST requests will no longer automatically retry after network errors
- Retry-After header now supports both seconds and HTTP date formats
- Optimized account pool scanning, concurrency control, and local overload handling
- Local overloads now clearly return a 503 and are no longer misreported as upstream rate-limits
WebUI
- Fixed garbled Chinese characters and abnormal replacement symbols
- Ensured consistency between the two sets of embedded WebUI resources
- Added the ability to manage multi-account bindings for API Keys
- Optimized display of account status, quota snapshots, and cooldown info
Temporarily Disabled
- Temporarily disabled the Microsoft 365 bulk user creation frontend entry
- Also removed related Graph configuration, authorization, and bulk-create backend routes
- Implementation code is retained for refinement and possible restoration in future versions
Official Release URL: v0.6.5
