[UlziX] Free zone users: renewal time is coming up in about a month, just a reminder
For the free tier, enabling auto-renewal will automatically generate a $0 bill, but you still need to click confirm manually to renew. This is only a reminder; you can log in to your account to check whether your instance was successfully renewed automatically.
Thanks for the reminder, I’ll renew right away~xhj15
Does automatic renewal continue until the deadline, or is it calculated in advance?
What does this mean? Non-zero yuan orders will have the balance automatically deducted 3 days in advance to renew the subscription, while zero-yuan orders do not support automatic renewal and have to be renewed manually.
The free tier has automatic renewal enabled. I want to know if the payment is deducted in advance.
The difference between enabling free auto-renewal and not enabling it is that, if it’s enabled, you’ll keep getting in-site notifications about renewal failures :ac47:
:sweat_smile: It’s free, and is there really no automatic renewal? I didn’t see anywhere to set that up.
There’s currently an issue with this logic. Under normal circumstances, after clicking the renewal popup, you should be able to cancel auto-renewal. However, in the free tier, if the renewal conditions aren’t met, you can’t click to renew, and therefore can’t see the option to cancel auto-renewal. This is a problem, and we’ll fix it within a few days.
Oh~ looking forward to a solution :partying_face:
The renewal is already done, thanks for the reminder.
Thanks for the reminder.
Has the free Hong Kong district 14 come back again?
Those moved to Zone 21 that haven’t been manually renewed yet will be automatically deleted if they aren’t renewed soon.
