I’ve hit a bottleneck and would like to collect the problems and pain points everyone encounters when generating images.
I want to collect some of the issues and pain points everyone encounters when generating images, like the situation below where you’re mostly happy with the result but need local fixes.
I added a mask repair feature, so you can compare it with the original image and avoid directly changing the prompt, which might accidentally alter other areas.
Face and hand corrections can be configured through custom backend workflows. I also created a direct serial workflow.
It feels like I’m just piling on features mindlessly. If you have any ideas, I hope you can share them in the comments. Thank you!
My personal image gen site here
Screenrecording_edited_compact
Why do this website’s dark mode and light mode completely change the overall look (
Most people play on a computer.
I don’t really get it—let’s take a look!
Can’t do micromanagement.
I don’t understand. I’m looking into it.
This actually isn’t really an issue.
  1. Anatomical and Detail Distortions
  • Problem: AIs often draw extra fingers, twisted limbs, asymmetrical eyes, or warped buildings.
  • Solutions:
    • Use negative prompts like bad anatomy, extra fingers, mutated hands.
    • Use the inpainting feature to select only the incorrect hands or faces for individual correction.
    • Include clear descriptions in your prompts, such as five fingers or symmetrical eyes.
  1. Text Rendering Errors
  • Problem: AI struggles to generate correct, clear, and error-free text in images and often produces gibberish.
  • Solutions:
    • Switch to a newer model with better text support (like DALL-E 3 or Midjourney v6).
    • Clearly specify text in your prompt using double quotation marks, for example: a sign that says "Open".
    • If AI-generated text fails, consider manually adding text in post-production using tools like Photoshop or Canva.
  1. Prompt Misunderstanding / Drift
  • Problem: AI ignores parts of your prompt or interprets metaphors literally, leading to results that are completely different from your vision.
  • Solutions:
    • Adjust prompt weights, using :: in Midjourney, or (keyword:1.2) in Stable Diffusion to emphasize key elements.
    • Rearrange your prompt following the logic: subject → detail → environment → style/lighting.
    • Simplify your descriptions and avoid overly complex or contradictory adjectives.
  1. Inconsistent Styles or Characters
  • Problem: When making a series (such as picture books or comics), AI often struggles to keep characters’ looks or art styles consistent across images.
  • Solutions:
    • Use the character reference feature, like the --cref parameter in Midjourney.
    • Use the style reference feature, such as Midjourney’s --sref parameter or the LoRA models in Stable Diffusion.
    • Give characters very specific traits (e.g. “red hair, round glasses, yellow hoodie”) and repeat these each time you generate images.
  1. Low Resolution / Blurry Outputs
  • Problem: Generated images have low resolution and become blurry when enlarged, making them unsuitable for printing or hi-res display.
  • Solutions:
    • Use the AI’s built-in upscale feature.
    • Use professional third-party super-resolution software (like Topaz Gigapixel AI, Upscayl, or Real-ESRGAN) for lossless enlargement.
    • Include terms like 8k resolution, highly detailed, or sharp focus in your prompts (although many modern models don’t strictly require these anymore).
The demand for unedited images isn’t very high.
I don’t understand.
Can’t micro.
The demand for raw images is not very high.
I don’t generate images; I’ll just grab a red envelope :ac01:
I’m here for the red envelope.
I don’t really get it—there are quite a few AI image-generation techniques too.
The 2D world, huh?
It depends on what kind of product you want to build. For ordinary users, it’s photo editing; for productivity, it’s an entire workflow—for example, turning images into 3D.
Image generation probably requires more detailed prompts, right? I’m not very good at using it :xhj17:
