The school uses some sneaky tactics, always targeting the students
When school started, I found that the VPN I set up with Oracle over the summer no longer worked.
Here’s the diagnosis GPT gave me:
I can only go back to using my previous subscription like a good little user.
:ac01:
Isn’t the campus network the slowest? :ac01:
GPT says a direct connection won’t work, so your original subscription was probably using a relay. Relays are pretty rare these days.
Our campus network runs pretty smoothly.
:xhj27:
The campus network definitely needs to put some restrictions on you.
Then your school is really quite generous.
Since TCP is being filtered, why not switch to hy2? :ac18:
hy2 is useless in rule mode; it only works when global mode is enabled
:xhj17:
Why? Isn’t this an issue with your local rules?
I don’t understand
:ac03:
Well, there’s nothing we can do now.
Wow, this is so shady…
That’s right, nowadays almost all of them are direct connections.
Feel sorry for it for one second, haha. Campus networks are just weird.
Just subscribe already!! It’s not like this little bit of money matters.
Could it be that your technical skills just aren’t good enough?
Of course the campus network will restrict what you can do—otherwise you’d just be bypassing the restrictions.
Now that the GFW is moving to a whitelist system, it doesn’t feel surprising that the school is doing the same…
I’ve put some restrictions in place—see how you want to handle it yourself.
The campus probably restricts the network because they’re worried someone might mess around with it.
