666clouds China Hong Kong VPS Benchmark
Brief review: This Hong Kong VPS has optimized routes for China Telecom and China Mobile on return paths. Average latency across the three major networks nationwide is approximately 35–51 ms. Disk performance is acceptable, while single-core CPU performance and network throughput are fairly average. No IP blacklist records were found, but its cleanliness score is only 75%, and AI service access is limited. It is suitable for lightweight websites, proxies, and basic network services targeting mainland China. Its main advantage is low-latency return routing; its drawbacks are the small configuration and incomplete streaming and AI service access.
Return Routes
- China Telecom: Beijing, Shanghai, and Guangzhou were all identified as CN2 GIA, with latency of approximately 9.2–42.3 ms.
- China Unicom: All three locations were identified as China Unicom 4837, with latency of approximately 21.3–54.9 ms.
- China Mobile: All three locations passed through CMIN2 before switching to CMI, with latency of approximately 10.3–54.7 ms.
In this three-location return-route test, China Telecom and China Mobile both used optimized routes, while China Unicom used the regular 4837 route. The route conclusions still need to be retested based on the actual access location and performance during peak evening hours.
Nationwide Three-Network Results (Latency and Packet Loss)
| Carrier | Average Latency | Latency Range | Average Packet Loss |
| China Telecom | 34.8 ms | 16.7–82.0 ms | 0.0% |
| China Unicom | 46.2 ms | 21.3–54.3 ms | 0.0% |
| China Mobile | 50.7 ms | 11.5–98.6 ms | 2.0% |
There were 102 test targets across the three networks, all of which responded. China Telecom had the lowest average latency, while China Unicom had the most concentrated latency range; neither experienced packet loss. China Mobile had the highest average latency, with 2.0% packet loss and more noticeable fluctuations.
IP Quality
The probe identified the IP as a Hong Kong data center broadcast IP. Its cleanliness score was 75%, with no listings across 106 valid DNSBL data sources. Most sources did not identify it as a proxy or VPN, and its risk rating was low. Port 25 is blocked, so it is not suitable for directly hosting an outbound mail service.
Streaming Service Access
12 of the 18 tests were available. YouTube Premium was identified as being in the Hong Kong region, while Disney+, Prime Video, Max, Hulu, and others were shown as available. Netflix only supported original content and was identified as being in the US region. Paramount+, ChatGPT, Claude, Gemini, and Reddit were blocked, and the DAZN test failed. Therefore, this VPS is not suitable as a node that relies on mainstream AI services or complete streaming-service access.
I/O Performance
The disk capacity is approximately 19.5 GiB, with about 15.4 GiB available. Sequential write and read speeds were approximately 248.3 MiB/s and 356.8 MiB/s, respectively. 4K random read/write performance was approximately 18.1k/47.6k IOPS, and fsync P50/P99 was 0.288/0.699 ms. Overall, it can meet the needs of lightweight websites and regular applications, but a single test is insufficient to represent sustained long-term I/O performance.
Overselling
CPU steal time was 0.0% in this test, and no hard resource limits were detected for the CPU, memory, or I/O. On the single-core Xeon E5-2680 v4, the SHA-256 and gzip tests achieved approximately 243.9 MiB/s and 136.7 MiB/s, respectively, which is suitable for lightweight workloads. Memory ballooning was enabled; 61% of the 991 MB of memory was in use during the memory test, and there was no Swap. No obvious CPU contention was observed, and I/O did not show abnormally low speeds. However, a single test is insufficient to determine whether the node is oversold. It is recommended to continuously monitor CPU steal time, I/O, and network fluctuations during evening peak hours.
Notes
- The configuration has only 1 core, 991 MB of memory, and no Swap, making it unsuitable for memory-intensive, highly concurrent, or continuously high-load services.
- BBR is not enabled. Probe speeds were approximately 127.8 Mbps download and 286.5 Mbps upload; a single result cannot represent long-term available bandwidth.
- The system runs CentOS 7, an outdated version that is no longer under regular maintenance. It is recommended to switch to a supported operating system before deploying in production.
- Some packet loss occurred on the China Mobile route. Retesting from the actual access location during evening peak hours is recommended before purchasing.
- IP risk, streaming service access, and AI service availability may change with platform policies. These results represent only this probe test.
Probe test: GSNode One-Click IP Cleanliness Evaluation Script 3.0 — Enhanced UI Edition
