# 我的免费百亿token计划
**URL:** <https://www.nodeloc.com/t/topic/107122>\
**Category:** AI\
**Created:** [2026 年9 月 7 日 07:35 UTC](https://www.nodeloc.com/t/topic/107122 "2026-09-07T07:35:31Z")\
**Posts on this page:** 9\
作者： ![lzA6](https://www.nodeloc.com/user_avatar/www.nodeloc.com/lza6/32/34501_2.png) [@lzA6](https://www.nodeloc.com/u/lzA6)\
发布日期： [2026 年9 月 7 日 07:35 UTC](https://www.nodeloc.com/t/topic/107122/1 "2026-09-07T07:35:31Z")
# 第一，你在这平台可以享受三个并发请求
> **[Freebuff — the free coding agent (free Claude Code, Codex, Cursor & Lovable...](https://freebuff.com/)**
> Freebuff is the free coding agent: a free CLI coding agent and Freebuff Web, the free way to build full-stack apps. No subscription, no setup, no lock-in. The free alternative to Claude Code, Cursor, Codex, Lovable, Replit, Bolt, Windsurf, and Devin.
> 也就是说有三个任务同时运行，免费的5.3 flash ，不限量
> ![60511a8670c4316276baff59341230d3](https://www.nodeloc.com/uploads/default/original/3X/d/8/d899c73566d4b1847c22c66307a18555d52b9074.png)
> **右边可以编排你接下来的任务**
 ![e7c02985d60edddbea3bc6b3fd0eb86a](https://www.nodeloc.com/uploads/default/original/3X/c/f/cff4603b65b9318d3f89696103bcb6ca503d2992.png)
## 100个豆一天，消耗五个豆可以获得一小时无限信息，但是你想，你也有挂机睡觉的时候吧？
> 我已经消耗了20M了，一会就这样了：
> ![9177067965da8e7944aa1bdc12efc268](https://www.nodeloc.com/uploads/default/original/3X/4/9/492921b7eb754c528121e3a37d6361e0f34b6de6.png)
# 第二，这边你可以获得不错的glm5.3 flash 不错的速度
> **[TokenRouter - Verified Models with Enterprise-Grade Controls](https://www.tokenrouter.com/)**
> A unified AI model hub for aggregation and distribution. TokenRouter converts leading LLMs into OpenAI, Claude, and Gemini compatible APIs with centralized management for individuals and enterprises.
 ![bda44684b86b21d47447b93017f24d28](https://www.nodeloc.com/uploads/default/original/3X/7/4/74a9d4eab0ed24c6dfeef8faa558b8de6c892a00.png)
> 没有并发限制，速度你看着来，反正这鸟模型本身不太快
作者： ![load](https://www.nodeloc.com/letter_avatar_proxy/v4/letter/l/958977/32.png) [@load](https://www.nodeloc.com/u/load)\
发布日期： [2026 年9 月 7 日 07:40 UTC](https://www.nodeloc.com/t/topic/107122/2 "2026-09-07T07:40:45Z")
作者： ![Foxx](https://www.nodeloc.com/user_avatar/www.nodeloc.com/foxx/32/21803_2.png) [@Foxx](https://www.nodeloc.com/u/Foxx)\
发布日期： [2026 年9 月 7 日 07:58 UTC](https://www.nodeloc.com/t/topic/107122/3 "2026-09-07T07:58:04Z")
Freebuff之前反代2个没怎么用封了，所以反代难搞，页面用用应该还行吧
# **glm5.3 flash** 和 **z-ai/glm-5.3-free** 应该是一个东东吧 :xhj09:
作者： ![xiaoyi669](https://www.nodeloc.com/user_avatar/www.nodeloc.com/xiaoyi669/32/63122_2.png) [@xiaoyi669](https://www.nodeloc.com/u/xiaoyi669)\
发布日期： [2026 年9 月 7 日 07:58 UTC](https://www.nodeloc.com/t/topic/107122/4 "2026-09-07T07:58:25Z")
感谢
作者： ![keioio](https://www.nodeloc.com/user_avatar/www.nodeloc.com/keioio/32/71472_2.png) [@keioio](https://www.nodeloc.com/u/keioio)\
发布日期： [2026 年9 月 7 日 08:45 UTC](https://www.nodeloc.com/t/topic/107122/5 "2026-09-07T08:45:44Z")
试了下，z-ai/glm-5.3-free 这个好像用不了
作者： ![fiona](https://www.nodeloc.com/letter_avatar_proxy/v4/letter/f/ecccb3/32.png) [@fiona](https://www.nodeloc.com/u/fiona)\
发布日期： [2026 年9 月 7 日 09:23 UTC](https://www.nodeloc.com/t/topic/107122/6 "2026-09-07T09:23:34Z")
大佬是真的强啊。
作者： ![luckyKing](https://www.nodeloc.com/letter_avatar_proxy/v4/letter/l/a3d4f5/32.png) [@luckyKing](https://www.nodeloc.com/u/luckyKing)\
发布日期： [2026 年9 月 7 日 12:16 UTC](https://www.nodeloc.com/t/topic/107122/7 "2026-09-07T12:16:43Z")
让我试试，谢谢大佬
作者： ![loc2024](https://www.nodeloc.com/letter_avatar_proxy/v4/letter/l/46a35a/32.png) [@loc2024](https://www.nodeloc.com/u/loc2024)\
发布日期： [2026 年9 月 7 日 12:34 UTC](https://www.nodeloc.com/t/topic/107122/8 "2026-09-07T12:34:52Z")
666 :xhj16:
作者： ![heyuxuanyyds1](https://www.nodeloc.com/user_avatar/www.nodeloc.com/heyuxuanyyds1/32/64387_2.png) [@heyuxuanyyds1](https://www.nodeloc.com/u/heyuxuanyyds1)\
发布日期： [2026 年9 月 7 日 12:36 UTC](https://www.nodeloc.com/t/topic/107122/9 "2026-09-07T12:36:18Z")
感谢分享这个东西
