James
September 14, 2026, 12:09am
Source code
nodeloc desktop application
Download
https://github.com/nodeloc/nodeloc-desktop/releases/download/v0.1.0/NodeLoc-Desktop-Setup-0.1.0.exe
This version has an updated installation interface and uses invox, making it look a bit better.
The layout has also been optimized. If you have any good ideas, feel free to submit a PR directly. Before submitting a PR, please make sure all test cases are present and pass.
Thank you for your hard work.
Once I have a token, I’ll submit a PR for a glassmorphism style
ketto
(KETTO)
September 14, 2026, 1:17am
7
NiuX Plus is now available on iOS, Android, and Windows—Linux is the only one missing.
James
September 14, 2026, 1:18am
8
Linux doesn’t do that. Does anyone even use GNOME anymore? Linux is all about the terminal—nobody uses a GUI.
Linux is all about using the terminal, right?!
YOUIMARK
(YOUIMARK )
September 18, 2026, 7:45pm
11
The check-in feature on desktop doesn’t seem to work—is it a bug?
IPLAY4LOVE
(IPLAY4LOVE)
September 19, 2026, 4:37am
12
Not bad, not bad It’s getting better and better, too.
James
September 19, 2026, 4:47am
13
It hasn’t been adapted to the new risk-control requirements.
ashangzi
(zack)
September 19, 2026, 5:46am
18
Hey, we could consider using Rust + Tauri for the tech stack and package it for all platforms in one go
James
September 19, 2026, 5:48am
19
It’s all the same: Tauri still uses the system’s WebView, while Electron merely bundles Chromium.
user94
(牢废物)
September 19, 2026, 5:49am
20
The one I made is nekoloc
Nekoloc —— NodeLoc 第三方开源客户端的全部版本变更记录。
各版本安装包与详细说明见 Releases 。
[v1.3.2] — 2026-09-05 · 发帖设备信息
新功能:发帖显示设备信息(对齐官方 APP)
移动端发帖 / 回复时,帖子下方显示设备徽章(如「Pixel 8 Pro」),与 NodeLoc 官方 APP 的 mobile_source 功能一致。
等级…
