WorkBuddy is kind of insane
It’s been reduced to a token emitter, just like zcode.
The agent Swarm feature has been abstracted into an Expert Team, complete with a bunch of ridiculous codenames.
When a command pops up that requires your approval, it doesn’t even tell you what the command is.
It only asks you to choose: Deny, Always allow, or Allow. So is there no “Always deny” permission?
What exactly am I denying? And what exactly am I allowing?
I’m working on a coordination workflow involving a main agent and sub-agents for writing plans, reviewing plans, feeding plans back in, and adversarial review of PR regressions. I’m also using MCP to manage permissions for bash commands.
And then it was instantly distilled into an Expert Team.
After using it, it just feels like a black box. I have no idea what it’s doing inside.
The level of customization is fairly low. I saw “hook” in the documentation and assumed there was a dedicated entry point for it.
For now, I still don’t know where this hook is configured.
What model are you running? Workbuddy now has a dedicated node in NL (whispers).
Free ds v4.1
What’s still free now?
HY4 ends on October 10; the others will all stop being free before October.
