If you’re looking for a static overseas IP, you can check out LinkStatic. I’ve also been testing it myself recently.
It mainly offers native static ISP IPs that remain fixed rather than using dynamic rotation. This makes it suitable for scenarios requiring a stable overseas network environment over the long term.
New users currently receive 50% off, with basic static IPs starting at $0.9/IP. That’s less than one dollar per IP, making it fairly suitable for buying one to test first.
Main use cases I’ve tested:
Overseas AI services such as ChatGPT / Claude / Gemini
Testing overseas websites and network environments
Social media platforms such as X / TikTok / Facebook / Instagram
Cross-border e-commerce platforms such as Amazon / Shopee / Temu
Multi-browser / multi-environment IP configurations
ASN / ISP / GeoIP / IP Reputation checks
My experience so far has been pretty good. What I value most is the fixed egress and long-term stability.
Prices vary by region, so you can check them yourself. The official website currently lists multiple regions, including the United States, the United Kingdom, Japan, South Korea, Singapore, Hong Kong, and Taiwan. The page also supports HTTP / HTTPS / SOCKS5 and states that the IPs are dedicated and come with unlimited traffic.
If IP attributes are important to you, I still recommend checking them yourself before or after purchasing rather than relying solely on the provider’s claims. Different testing platforms may produce different results, and actual performance should also be evaluated based on your own network environment.
50% off your first order for new users, starting at $0.9/IP:
LinkStatic static ISP official website: https://linkstatic.com/?kwd=s-Loc
If you need a fixed overseas IP, you can test one yourself and continue using it long-term if it works for you.
