Sharing canceled, update canceled
Most Outlook emails end up in the spam folder.
It depends on the platform. On some platforms, domain email accounts have low reputations, while on others they perform much better.
Let’s make a setup tutorial.
This one was also built using someone else’s open-source project. I’ll see if I can make a setup script.
Serverless deployment tutorial. This project can extract the client ID and RefreshToken. Once it’s set up, it can extract the email address, password, client ID, and RefreshToken from the mailbox, which can then be imported into other webpages to retrieve mail. Normally, it supports saving and sharing through a server, but this tutorial uses a serverless Render deployment. I’ve heard that the free version doesn’t include Persistent Disk, but you can still try it; it works for short-term storage. If you have a server, I can also make a server deployment tutorial.
Okay, thank you.
A permanent email address?
Yes, there will be other Outlooks later, but they won’t use the same URL.
Thanks, boss!
This project is excellent.
Okay, thank you.
