A\ is much stricter now—you have to log in and authorize again every time you switch nodes
I’ve run into these two several times. Regardless of whether there are tasks running, as soon as I switch networks, Claude Code immediately stops and asks me to authorize again.
Don’t switch networks casually from now on—there are definitely security checks in place.
GPT as well
I usually add a routing rule to the AI group. The primary node can be switched freely without affecting the AI.
I still need to find a way to get some residential IPs on hand.
Isn’t this Wrangler?
