github has a more detailed description; this is the Android app made by the second Agent.
I don’t usually need this, but whenever I do need to find it, it’s a real hassle. Thanks.
I was originally planning to make a few EVA skins, but after thinking it over, I decided against it. ![]()
I don’t actually do this either. I usually keep them in Notepad, but it’s indeed rather inconvenient. This app has an import feature, so if you’re interested, you can use AI to put your current passwords into an import file and then import it directly. It’ll be much more convenient. Haha ![]()
