Does anyone have any ideas for setting up some services for everyone to use together?
I can provide the servers, as long as they’re set up for everyone to use.
If you need a server with specific specifications, just leave a comment.
Calculated
Set up a reverse-proxy URL service—the base URL of the reverse-proxy relay.
It does. Could we set up an FRP service?
calculate
Setting up a KMS should take about 1 vCPU, 1 GB of RAM, and 10 GB of storage.
There’s also an AI gateway, which would need about 2 vCPUs, 2 GB of RAM, and 30 GB of storage.
Would that be okay?
Sure, but what is KMS? I’m not familiar with it. Could you please explain it to me?
Thanks for your reply. Do you want one? I can give you one, but I can’t guarantee that it’ll work.
You’re insanely good—are you already good enough to see someone off at the airport?
No, no—I just can’t use it all myself. I’m seeing if anyone has any ideas; we could set it up for everyone to use together, so it wouldn’t go to waste.
Would RustDesk work? I need it for remote collaboration. It relies quite heavily on network quality, so a server in China would be preferable. As for resource usage, it’s very light.
Looks like I don’t have a China-based server ![]()
What can’t we deploy an online game where only NodeLoc members can play online together?
I previously got a one-month Go plan from mirasim. I heard that using a reverse proxy gives better results (the mirasim client has some flaws).
Could someone make a website where accounts can be uploaded and used, while also supporting direct connections?
I think this idea is pretty good. Does anyone experienced have any ideas? I can provide a server, but I’m not very good at setting it up.
Sure.
One is mooching off Microsoft for Office and Windows activation, while the other is mooching off Microsoft for Office and Windows AI ![]()
I can set up the machine for KMS first. I don’t currently have enough quota for that one, so I can’t start it.
But how do I send a private message here?
