I’ve recently been using a free AI video editing software called OpenChatCut. Overall, the experience has been pretty good. Deploying your own text model unlocks most of its features, including having AI edit videos for you. However, it lacks text-to-image and image-to-video models. Can anyone point me to a source for them?
For image-to-video, MiniMax-H3 performs well, but a few API details can easily cause issues:
- For I2V, send only
first_frame; don’t also includereference_image(it will returnroles cannot be mixed) - Don’t make the input image too large. I had to re-encode portrait images to 720×1280 before things became stable
- The generic
imagesfield doesn’t work on this channel; use the field name specified by the model
Text-to-image/text-to-video are relatively easy to fine-tune; if you mainly work with I2V, aligning the resolution and role fields first will help you avoid a lot of pitfalls.
Come freeload off my relay for a bit
It depends on the model. Seedance is basically out of the question—it’s too expensive.
About how long will a balance of 0.5 last?
