Do you have any recommendations? Some of the prices are a bit too high for me.
Passing by
Take a look
hao
Take a look
Please show your support.
Dude, you can’t just collect the red envelopes—could you tell us how?
Let’s take a look at this article.
The principle is similar, so you can use it as a reference. The only downside is that the operating and maintenance costs are a bit high.
You need a good environment to use CC.
I have an overseas server on Tencent Cloud with one IP. I used it with an anti-detect browser, and it hasn’t been banned all morning, so it should be fine. I have a clean IP—does that mean I can deploy it on my Tencent Cloud server?
You can give it a try.
I’m currently using a sub call, but I’m worried this might not work for CC.
No guarantee it will work, because the OP only posted the GPT method.
Sure, definitely. Use it as a relay.
