[Results announced] Zynk public-interest site | Chinese models | GPT | Claude
ModelOC claude-sonnet-5 Anthropic · free.zynk.bot.cd 评级 B 评分 82 风险 低 覆盖率 78.6% · 可信度 MEDIUM · 引擎 2.6.4 通过 12警告 1失败 1不确定 3 测试时间: 2026-09-29 08:43 UTC
Look here: If you win the giveaway, send me a private message on the site
Public-service site, pay per use; check in daily to earn $10
Link: free.zynk.bot.cd
Daily quotas depend on the model limits; see the site for the specific rules. Claude and GPT are available by the hour.
I managed to catch up once.
Thank you for your generous sharing~ Please like and support~
Wow
Thanks for providing the information~ Give it a like~xhj15
Data cleared at the end of the month? Can I only take advantage of it for one day?
Take a look.
No reset this month
Okay
pull
Middle Middle Middle
You’re late, so no red envelope—try your luck with a draw~
Join in.
No red envelopes
Try entering the lucky draw
pull
Thank you for providing the information.
I’ll join in too.
What matters is taking part.
It’s the participation that counts.
middle
