Developed a small app, HexoManager, to make managing Hexo sites easier—feedback welcome
HexoManager
Desktop Hexo multi-site management tool — manage multiple Hexo sites through a graphical interface, covering the entire workflow from writing to publishing.
Tauri
React
TypeScript
Rust
License
Project Overview
HexoManager is a cross-platform desktop application built with Tauri 2.x + React 18 for centrally managing multiple local Hexo blog sites.
The traditional Hexo workflow requires repeatedly running hexo new, hexo g, and hexo d in the terminal. When managing multiple sites, you also have to switch between directories and manually maintain CI configuration files for each platform. HexoManager brings these operations together in a graphical interface:
  • Keep all sites in one place and switch contexts with one click
  • Edit articles with Monaco Editor and preview the rendered Markdown in real time on the right
  • Edit _config.yml visually while retaining the original YAML mode
  • Generate CI/CD configuration files for 7 major deployment platforms with one click, including edge-layer origin-fetch strategies
  • Automate the entire build, commit, push, and deployment workflow with complete log recording
Data security: All site data is stored in the application’s local SQLite database, while site source code always remains in the original directories you specify. HexoManager never copies or uploads them.
Features
Module Capabilities
Workspace Current site statistics overview, recent articles, recent deployment timeline, and quick site switching
Site Management Four-step creation wizard, import existing sites, card/table dual views, detailed statistics, copy, backup, and deletion with optional file cleanup
Article Management Monaco Editor + real-time Markdown preview, three layouts, 30-second auto-save, Ctrl+S, metadata and version history, publish/unpublish, and batch import
Categories & Tags Category and tag distribution statistics, article associations, renaming, merging, deletion, tag cloud, and category tree
Configuration Management _config.yml visual form + bidirectional raw YAML editing, real-time syntax validation, read-only preview, export/import, diff comparison, and backup restoration
Theme Management Installed theme grid, theme marketplace, npm/git installation methods, and theme configuration YAML editing
Plugin Management Toggle between installed-plugin table/card views, 12 recommended plugins with category filtering, installation command preview, and plugin details
File Management Directory tree + file list/editor switching, breadcrumb navigation, creating files and directories, renaming, deletion, and hidden-file toggle
Local Preview Environment detection, starting/stopping hexo server, multiple ports in parallel, and build operations (clean/generate/build/deploy) with real-time logs
Deployment Configuration Seven major platform cards, build and repository configuration, edge-layer strategies (EdgeOne / Cloudflare / dual edge), configuration preview, and one-click writing
Git Operations Status overview, change list with staging/discarding, commits with quick feat/fix prefix tags, history and rollback, remote repository configuration, and diff viewing/export
Deployment Records History table with filtering/sorting/search, log details drawer, export, rollback, success rate, and duration statistics
About & Updates Software information, technology-stack layered view, update checks, downloading and installation, automatic check toggle, version ignoring, changelog, and open-source licenses
Message Center Notification list grouped by type, unread filtering, and preview service management with start/stop controls
Preferences Theme mode, editor font size, auto-save interval, confirmation for dangerous operations, default values for new sites, and local data management
Technology Stack
Frontend
Component Version Description
React 18.3.1 UI framework
TypeScript 5.7.3 Strict mode with any disallowed
Vite 5.4.11 Build tool
Ant Design 5.29.3 Component library with Chinese locale and light/dark theme algorithms
Tailwind CSS 3.4.19 Utility-first styling, with preflight disabled to avoid conflicts with the AntD reset
Zustand 4.5.7 State management with 6 stores
React Router 6.30.6 Hash routing adapted to Tauri’s local protocol
Monaco Editor 4.7.0 Code and Markdown editor
react-markdown + remark-gfm 10.x / 4.x Markdown rendering
Backend (Rust)
Tauri 2.x Desktop framework
rusqlite 0.32 SQLite bindings (bundled included, with no system dependencies; WAL mode + foreign-key constraints)
tokio 1.x Asynchronous runtime
handlebars 6.x CI configuration template rendering (include_str! inlined at compile time)
serde_yaml 0.9 Reading and writing Hexo site and theme YAML configurations
walkdir 2.x File-tree traversal
reqwest 0.12 Update checks (rustls-tls)
https://github.com/xfm0797/HexoManager
Thanks for sharing so selflessly~ Giving this a like to show my support~
Thank you
Thank you for your selfless sharing.
Thanks for sharing
If you find any bugs, please feel free to report them.
This definitely deserves a star.
Tauri is a great choice for desktop apps, with a much smaller footprint than Electron. It would be a good idea to add an article front-matter template feature, so you can apply commonly used fields with one click when writing a new article.
Thanks for sharing
There’s metadata information above the new article editor. I’ll take another look and see if I can add a template feature directly.
Thank you
