Add a new model! Fledge Alpha
Fledge Alpha is a multi-model routing gateway. It routes models such as DeepSeek V4.1 and Kimi K3.
Input
0.05
Output
0.15
Unit: energy / 1M tokens
It’s pretty decent, I guess.
By the way,
it now supports OpenAI-, Anthropic-, and Reasoning-compatible APIs.
We can now use it with Codex, Claude Code, or any CLI tool! (Let’s forget about Gemini—does anyone really use this compatibility interface?)
Very cool, I’ll give it a try.
What kind of interface is Reasoning? I haven’t used it yet.
OpenAI Reasoning-Compatible API
Differences from /v1
Will image/video models be added?
I did a quick search, and it looks like you use the responses API and control it through parameters?
That’s right.
There may be more to come.
