James
October 3, 2026, 12:20pm
GPT’s reset resets you ahead of time, and after the reset, a new 7-day period is calculated;
Claude’s reset adds an extra reset in the middle, while your original reset time remains unchanged;
So, it seems that Claude’s reset is much more useful than ChatGPT’s.
Mike-Leone
(Mike Leone)
October 3, 2026, 12:26pm
There’s a problem with this: if the quota is forcibly reset a day before the normal reset, it’s easy for some of it to go unused and be wasted.
Indeed, if GPT keeps using something like CC, I don’t think becoming the leader on the consumer side would be a problem. After all, who doesn’t love a reset?
wuyee
(wuyee)
October 3, 2026, 1:06pm
4
Each has its pros and cons, I suppose.
