Could the requirement for upgrading to Gold membership be lowered a bit?
In other words, if you don’t eat, drink, or sleep, and grind on nodeloc for 125 days, you can max out the 3,000 minutes :xhj32:
You missed the last train.
The number of days is easy; the hard part is the view count. I even dream about reaching 50,000 views and leveling up to Diamond(
It can be met by intensive grinding; the strictest limit is the number of days.
Reading time is really difficult.
Diamonds are the hard part.
I’m still 300 minutes short of reaching Silver for reading time. How much longer will it take?
Let’s take it slow.
There was a period before—probably two or three months—when it was only a little over one-tenth of its current intensity, and you didn’t go for it…
Take it slow and keep grinding.
Climbing to Gold is so hard.
That hits hard
Prepare gold
I was just about to hit like.
Tell James to lower the difficulty a bit.
The requirements for Diamond really are too high—you’d have to grind intensely, just like the expert above said, to achieve it.
P.S. I always thought you were already Diamond.
They lowered the difficulty before, which led to a bunch of services being abused. There was no choice—Lao Zhan had to put it back.
Diamonds aren’t that easy to get (
The historical threshold is too difficult to reach, while this 100-day limit is easy.
I don’t know what’s going on with this reading time—I can’t increase it by even a minute.
Give Muse the login and leave the account logged in so he can take a look. As for the posts, just post something useful yourself from time to time.
