apinex Free Perks: Each Account Gets 10 Million Tokens of Free Model Credits Every Day
Website: https://apinex.bond/
Registration method: Direct access with a Google account
Sharing link code: VKC3C6DG
Free benefit: Each account receives 10 million tokens of free model usage every day
Same-day quick reset code: APX-4NY5-EKED-CF5E
[upvote][/upvote]
Take a look
Take a look
Let’s see what models are available.
I registered before, but the free model is basically unusable.
Result from deepseek4.1flash. There’s also a bit of an issue with the billing—it gets used up incredibly quickly, so there’s no point wasting time on it.
Okay.
Because you have to pay to use it.
I need to top up.
It works for small-scale use.
Only models marked as free can be used. Just filter them.
Models with freec can be used.
You’re freaking awesome, boss!
Thanks to the OP for sharing.
Thanks for sharing
It works, but you need to follow and join Telegram to get $0.10, then use a reset code. You can get 1 million tokens, but they run out quickly.
x3 Of course it’s fast!
The free version is basically useless—you can’t use any of it.
