Yes, you can log in through both the web and the client.
So far, aside from the one mentioned above who reportedly had their account banned, there haven’t been any other reports of bans. I’ve been using it myself for a month or two, and it’s been working normally.
It’s the same models available on Plus; Work and Codex can use up to 6.1.
It makes me so wary that I don’t even dare use his desktop app anymore—it grants access to everything to any software that can use it…
If I buy it, can I use it indefinitely, or will I be kicked out after a month?
The shop is on kiro edu now—what do you think of this thing?
Never used it ![]()
How much are you selling it for?
Is the 5-unit minimum available yet? Also list a few 1-space options.
Is this cheaper than transshipment?
just a quick question , is the reset provided by openai not valid for this k12 just only getting the normal weekly reset
K12 accounts are not included in the reset plan.
okay and why is the 6.1 terra still not available?
Why don’t you sell Single Space K12 anymore?
Hard to say. Even if you get kicked out after a month, you’re still guaranteed to make a profit. My hosting space was suspended after just over ten days—it really depends on luck.
Some spaces have been getting suspended recently. It feels like reverse proxying and reverse engineering are triggering the platform’s risk controls.
Is Claude available?
what
