Free 4H8G Server Keep-Alive — instabox.sh
instabox Is this an invitation code?
need invitation code…anyway,thank you for this method
Let me guess… pingmike2?
So now it will be forced to shut down before eight hours have passed, right?
Are you still there? No way, did they ban it?
I deployed a WP music site: https://wp.kinai.cc.cd/
How do I set up this node? I set it up using the X3-UI panel, but why isn’t the node working?
How do I configure 3X-UI? Why can’t I get the nodes to connect no matter what I do?
It’s still there—I just had AI put it together for me. Looks like it uses WebSocket.
Are there more free machines?
I received the invitation code today, but I don’t know how to use it…
Could you show me how to configure the inbound and client settings? I asked AI too, but it couldn’t solve it either.
If you’re developing with Claude Code, you don’t need to worry about it—just let Claude handle it. After all, it’s designed specifically for AI development and running tests. It’s really useful, haha. You don’t have to run E2E tests locally anymore.
This could even be developed into a way to use servers for free, uh… :06-chigua:
If you’re only setting up a proxy node, I’d advise you not to spend too much time on it, since the daily time limit has already been set.
You might as well take a look at the game console I mentioned earlier. I turned it on in April this year, and it’s still running fine. The highest speed I’ve measured here is 21 Mbps, which is good enough.
After seeing the constraints, I decided to set it aside for now.
I used the simplest method: I created a connector directly in muse using the API and set it to activate periodically.
Thanks to the original poster for sharing.
Sure. Just configure it directly in Muse.
