Free AI on Telegram and WhatsApp that can generate images and videos—you deserve to have it
AFF : Meet Pally
If you sign up and use it successfully through my link, both you and I will receive a reset voucher. Sorry to bother everyone—although I won’t be able to use them all, I’d like to get a few more.
You can connect it to other software via MCP. In other words, as long as you have enough accounts, you can apply for quite a few of them, with each account having its own separate quota, provided they aren’t linked to the same AI assistant. It’s just taking advantage of the free perks, though its main function seems to be ordering takeout and buying things. It can also make phone calls, but don’t expect it to call numbers in China—it won’t connect. I won’t go into its other features; find out for yourself.
Yesterday, I had this AI generate images and videos at the same time as Muse AI, Hark (which can’t generate videos), and Grok Bot. It was the fastest so far. Its generated videos were also smoother than Muse AI’s.
A 2-minute-10-second video used 0.1% of the quota, and the quota recovers in real time, so you don’t have to wait. You can do the math yourself: one image and one 10-second video only used 01.4%. That’s pretty incredible.
Here’s an image I had it generate:
Here’s a video I had it generate:
Burning Formula
Seems pretty good.
With the free version, you can’t choose the model—it uses automatic routing. But it can generate images and videos, so it’s multimodal.
Take your time to appreciate it.
Looks pretty good.
Give it a try—it’s free.
Not bad, not bad
Post a tutorial.
Tsk, I wanted it to generate an image of a beautiful woman in a bikini, but it refused :xhj001:
Could you phrase it differently, haha
Pretty good—the response time is really fast.
Let’s see how it goes.
MCP works.
Okay, thanks.
