[Sharing/Looking for feedback] I made a clean, ad-free IP lookup tool (ip.fs.kg)—feel free to give it a try!
Hello, community friends:
To make it easier to check network nodes and IP status in daily use, I created a lightweight IP lookup tool: https://ip.fs.kg/
Features:
Accurate geolocation: Supports looking up an IP address’s location, ISP, ASN information, and latitude and longitude.
Dual-stack detection: Automatically identifies and displays the IPv4 and IPv6 addresses of the current connection.
Minimalist experience: Fast page loading, with no pop-ups or cluttered ads.
I’d love to hear what you think:
Could the interface layout or user experience be improved?
How fast are lookups under different network conditions (mobile/China Telecom/China Unicom/cross-border nodes)?
Which metrics do you care about most when looking up IP addresses (such as WebRTC leak tests, DNS poisoning detection, fraud scores, etc.)?
Everyone is welcome to try it out and leave valuable feedback. I’ll continue improving and iterating on it!
Good tool
Can it be open-sourced?
Nice tool, looks pretty good.
Awesome!
Familiar, as if we’ve met before
The interface looks pretty good.
Great stuff, really nice—thanks for sharing.
That’s not right—it located me somewhere else.
Try again—there are five data sources to compare.
Great tool!
Last time, the error was located in Beijing; this time, it was located in Shenzhen. It’s still not accurate, but it’s much more accurate than last time.
Will you open-source it? If so, could you explain how to deploy it to CF?
Why is the city shown by the lookup different from my actual location?
There are three common reasons: you’re using your carrier’s centralized gateway (the metropolitan-area network gateway often isn’t in your city); you have a proxy or VPN enabled, or are using a cloud service provider’s network node; or your network uses a shared address (CGNAT). In all three cases, the location shown is that of the egress router, not the physical location of your device—no IP lookup tool can determine the latter.
It won’t be open-sourced for now.
Great project
Thank you for your support.
Sounds good, I’ll give it a try when I have time!
You can give it a try.
I almost thought it was IPFS…
The interface looks good.
