[Winners announced] Giving away three VOXI numbers (rebind them to your own email)
The cards opened this month are valid for 180 days. You can top them up and use them for transactions to keep the numbers active.
Only Remitly has been registered; all the other apps have also been registered.
Since they’re being “given away,” each person can receive a maximum of 10 tickets.
If there are many participants, I’ll probably give away around 3–6 more later.
Numbers:
7555365034
7552522091
7350492283
The first people to send me a private message can choose first. (The number of prizes for each tier seems to have to be set differently, so I can’t simply hold a random draw.)
As for Voxi, I mentioned it in a previous post:
It can be used directly in mainland China. (If a direct connection doesn’t work, you can change the APN.)
Roaming SMS messages cost £0.24 each, or £0.20 each when using Wi-Fi Calling.
After you win, send me a private message to change the email address linked to the account. Change the password yourself once you receive it.
Join in.
I’ll give it a shot—hopefully I win.
Try your luck
Thanks, you’re a legend!
Thank you for your support—please get involved.
Come join in.
Come join in!
Try your luck
Could changing the linked email address expose any information? Roaming SMS messages cost £0.24, which isn’t cheap when converted to RMB either.
Join in.
Let’s do one pull to test the waters.
Get involved firsthand
Try your luck
What information is being leaked?
It’s only 5 yuan a year—changing it once every 180 days is enough :09-kaibai:
Participate td
I’m here.
Give it a try
Give it a try
Participation
