Moreover, since it hasn’t been used at all, it will be deleted soon.
Point the domain to your own server, then configure the project’s domain on the server, and it’ll be ready to use. I use Baota Panel (宝塔) to configure the reverse proxy directly.
In Cloudflare, find a Pages project, select Custom domains, and add the domain you registered on Yunamo.
In the second step, under DNS configuration, select My DNS provider.
Copy the name and target, then go to https://yunamo.com
Enter them here.
After a few minutes, check the custom domain for the Pages project. If its status shows Active, the setup was successful.
If the custom domain for the Pages project doesn’t show as active:
Go to your domain on https://yunamo.com and scroll down.
First disable DNSSEC, then enable it again, and click Republish DS to Zone.
Thanks, I’ve already added it, and the domain works too. However, the domain management page on the website says the domain is unavailable. Oh well, I tried my best—if it can’t be kept, there’s nothing I can do.
I don’t know what’s going on.
Oh, oh
Learn a bit
If detection fails for 30 consecutive days, the domain will be deleted…
