Finally a Silver member! hz
Finally a Silver member!smiling_face_with_three_hearts:
Congratulations!
Congratulations, congratulations! I also reached Silver yesterday :04-zan:
Keep it up—greater heights await you! :11-moyu:
Keep it up!
Keep it up, OP!
Congratulations!
The new member has arrived—congratulations!
Same to you, hehe
That day, I opened the webpage here, went to look at other tabs, and occasionally came back to click and switch to another post, but noticed that no time had been added at all… It seems you can’t leave this tab.
Congrats, OP. My online time hasn’t increased for ages, and browsing posts doesn’t help either. How do you increase yours?
Use this self-service unblocking tool to check:
https://www.nodeloc.com/risk-control/appeal
If it says:
No restrictions
No restrictions of any kind
then your account is in normal status!
If it says “cleared,” that means your account is under a restriction period. Submit an appeal according to your situation. If the result says the original decision remains unchanged, wait a few hours, half a day, or a day or two for manual review!
If it still doesn’t work, send a private message directly to an administrator (you can find one on the site or in the Telegram group) or mention the moderator @james James, and that should do it!
How do I upgrade? I want to speed things up.
If it says:
No restrictions
then everything is normal!
If it says “cleared,” that means the account is in a restricted-period state. Appeal as appropriate. If the result still says the original decision remains in effect, wait a few hours, half a day, or a day or two for manual review.
If it still doesn’t work, simply send a private message to an administrator (you can find one on the site or in the Telegram group) or to the moderator @james (James).
Congratulations, congratulations~
Check it using this self-service unblocking tool:
If it says:
No restrictions
If it says the restriction period has been reset, that means the account is still under restriction. Appeal as appropriate. If the result says the original decision is upheld, wait a few hours, half a day, or a day or two for manual review.
If it still doesn’t work, contact a moderator on this site or in the Telegram group.
Keep going, the future is bright, though the road is long…
Congratulations to the original poster!
Congratulations
Thanks, boss. Looks like there’s no limit—you just slowly rack up the time, I guess.
