Huorong and 360 both seem pretty mediocre.
Just go naked, haha.
I use Huorong to block pop-ups.
Windows 11 doesn’t need antivirus software; what you should protect yourself against is AI.
I use Kaspersky.
I’ve tried a lot of them, but I ended up sticking with 360. I’m used to it now, and the current version doesn’t use much space or resources anyway. I could actually do without it—I’m just worried about viruses. Better safe than sorry, I guess.
If you really need antivirus software, use 360 or Kaspersky.
Isn’t the system’s built-in one good enough? I feel like 360 only offers some protection to computer novices.
There’s no single best or safest option—only personal preference.
The Huorong antivirus I installed for a client seemed pretty good at first, but today I discovered the computer had been infected, so I downloaded 360 Antivirus instead.
I haven’t installed anything like this in many years.
I feel the system’s built-in security software is enough. In fact, if you understand computers and operating systems and don’t install unknown software recklessly, you’ll generally be fine.
I used Huorong for a few days, but couldn’t get used to it, so I switched again.
Feels pretty useless.
I’ve always run things bare-bones: install whatever needs installing, keep backups, and reinstall whenever something goes wrong. Couldn’t be more satisfying.
Kaba (卡巴)
Huorong—after going around in circles, it’s still Huorong.
If you ask, it’s Kaba.
Huorong, I guess. It’s not that shady, and as long as it keeps some boundaries, that’s good enough.
Nothing at all. I don’t keep anything important on the computer, so whatever.
I recommend Kaspersky. I installed Huorong myself. It feels like installing antivirus software is just psychological comfort…
