Which antivirus software is the best and safest?
Disconnect from the internet, shut down—super safe!
Kaspersky has both paid and free versions.
The built-in protection is actually sufficient; the key is not to install software from unknown sources indiscriminately.
In this day and age, you’re still worrying about antivirus software? Totally unnecessary.
Windows Defender
Kaspersky
Avira
Of course, if you’re confident you can deal with 360’s ads, then 360 is still the best choice.
Running naked
For beginners: 360; paid: ESET; the best: Kaspersky; anything else means going unprotected.
The built-in one is enough.
If you’re on Windows, you can just go without one. If Windows’ built-in option doesn’t work, the others are basically just memory-hogging window dressing anyway.
Ham
360
Are you asking which antivirus software can make your computer safer, or which one isn’t shady and is safe to use itself?
AI is a giant Trojan horse.
I used a tool to disable Windows Security Center, and I’ve been running unprotected ever since.
I’ve been using Huorong all along.
Are there still computer viruses these days? I’ve never installed antivirus software.
Running naked
