By the way, do you keep your VPN on all the time?
No need.
Set up the rules and keep it running all the time!
Set up your own relay with a clean IP, so you won’t need to keep using a proxy and won’t have to worry about your local environment.
Just leave it on; there’s no need to turn it off. If the traffic routing is configured properly, it won’t have much impact.
It stays on, but my phone keeps disconnecting on its own :downcast_face_with_sweat:
I often forget to turn it off :joy::joy:
Turn it on when you use it, and turn it off when you don’t. Sometimes I forget to turn it off. What’s the problem?? :06-aoye:
Thanks for sharing this content. I stopped by to check out the introduction and discussion.
It doesn’t affect anything either, so turn it on if you want. All I know is that some company whose name starts with A needs it to stay on all the time.
I always keep Quantumult X running on my phone; I never turn it off.
I don’t think that’s a saying.
Just leave it on, use rule mode, and bypass mainland China—that’ll do it!
It’s always on.
Rule mode is always on
The computer stays on all the time; I turn on the phone when I use it.
Set the rules properly and keep it running 24/7 without worry.
Rather than believing X, you might as well believe me—I’m Qin Shi Huang. Take a gamble; you never know. Send me 3,000 on WeChat, and I’ll appoint you Grand General Protecting the State.
It’s been running the whole time. Once the traffic routing is set up, there are basically no problems.
